Color
So, I’ve noticed that after I start editing MD files some links will turn dark blue, while other will remain in their original purplish color.
- Why does that happen?
- Is there a way to keep them purplish? I much rather prefer it that way, since dark blue is harder to read with a dark background.
Links with MD syntax and callback links
Callback links and other links using MD syntax reset every time I open the file.
What do I mean by that?
It won’t appear as a link before I edit the link in some way. Once I have done that, it will turn into a proper link and become clickable.
A bug, perhaps?
Annotations
Although I set my preferences for rtf files to white letters on a dark background, when I type on the annotations field of a pdf file, the created rtf file appears with dark letters on a white background.
Is there a way to change this behavior?
