3.0: Search results for Kind is Group and one more issue
(1) Both tags and groups are listed when Kind is Group is used, but when Kind is Tag is used only tags are display (which is the correct results)
(2) When an alphabet, e.g. “a”, is hitted in the drop down list of smart rule/group, I think the selection should jump down sequentially to items that begin with “a” but it doesn’t. Not sure if it’s intended behaviour.
Thanks in advance
That’s correct - each tag is also a group.
This is unfortunately completely handled by macOS, therefore I’m not sure about its intended behaviour.
Thank you. Simple work around is available anyway if only groups are wanted (Kind is Group & Kind is not Tag).
