Purpose:
A flexible date string and date format generator for the creation of contents and group/file filename. The shell script ‘date’ is powerful, but it can only manipulate the current date (TTBOMK). The handler provides a single interface to handle both systems date stings (by using shell script) and arbitrarily assigned date strings (by using AppleScript ).
Demo
set curDate to current date
set aDate to date "Sunday, 10 May 2020 at 10:10:00"
-- use curDate
return my getDateStr(curDate, "A, d B Y", "+1m")
-- Wednesday, 03 June 2020
return my getDateStr(curDate, "d-B-Y I:M:S p", "+2m")
-- 03-July-2020 04:05:19 PM
return my getDateStr(curDate, "Y.m.d.H.M.S", "")
-- 2020.05.03.16.04.57
return my getDateStr(curDate, "Q", "+1w")
-- {"04.05.2020", "05.05.2020", "06.05.2020", "07.05.2020", "08.05.2020", "09.05.2020", "10.05.2020"}
-- use aDate
return "The week number in 12 weeks from aDate is week " & my getDateStr(aDate, "V", "+12w")
-- The week number in 12 weeks from aDate is week 31
return my getDateStr(aDate, "A r", "")
-- Sunday 10:10 AM
return getDateStr(aDate, "q", "-1m")
-- {"10.04.2020", "11.04.2020", "12.04.2020", "13.04.2020", "14.04.2020", "15.04.2020", "16.04.2020"}
Parameters accepted by the script
Note
- The input parameters to the handler are case-sensitive. The letters used for the parameters are exactly the same as shell script of ‘date’. Except for Q and q.
-- CASE SENSITIVITIVE parameters for theDateFormat
-- Comment: the parameters are identical to shell scipt of 'date' except for Q and q
-- Q and q are customised to generate an array of 7 days
-- Y long year (e.g. 2020
-- y short year (e.g. 20)
-- m month ( e.g. 01..12)
-- B long month name ( e.g. January)
-- b abbreviated month name ( e.g. Jan)
-- d day of moth (e.g. 01..31)
-- A full weekday name (e.g. Monday)
-- a abbreviated weekday name (e.g. Mon)
-- R 24-hour time (e.g. 16:10)
-- r 12-hr clock time (e.g. 4:10 PM)
-- H hour (e.g. 00..23)
-- I hour (e.g. 1..12)
-- p AM/PM (e.g. AM/PM)
-- M minute (e.g. 00..59)
-- S second (e.g. 00..60)
-- V ISO week number - Monday as 1st day of week ( e.g. 01..53)
-- Q an array from Monday to Sunday of a given ISO week num ( e.g. {27.04.2020,...03.05.2020})
-- q an array of a given date and the following 6 days
-- CASE SENSITIVITIVE parameters for theOffset
-- y +/-years (e.g. "+2y" or "-2y")
-- m +/-months (e.g. "+2m" or "-2m")
-- w +/-weeks (e.g. "+2w" or "-2w")
-- d +/-days (e.g. "+2d" or "-2d")
-- H +/-hours (e.g. "+2H" or "-2H" )
-- M +/-minutes (e.g. "+2M" or "-2M")
-- S +/-seconds (e.g. "+2S" or "-2S")
The handlers with the main handler and a utility handler
- Please kindly let me know about the bugs. Date manipulation is tricky - I still get the arithmetic wrong sometimes.
- It’s a long script, but hopefully it can save time by avoiding repeated codings of similar formats. The comments in the handler can be a quick reference of the ‘date’ syntax, too.
- If there are other means to achieve similar/better consistency of interface and functionality, your advice will be valuable!
use scripting additions
on getDateStr(theDate, theDateFormat, theOffset)
--by ngan 2020.05.03
-- Main
set ltd to {{"y", 365 * days}, {"m", ""}, {"w", 7 * days}, {"d", days}, {"H", hours}, {"M", minutes}, {"S", 1}}
set lol to {{"Y", ""}, {"y", ""}, {"m", ""}, {"B", ""}, {"b", ""}, {"d", ""}, {"A", ""}, {"a", ""}, {"R", ""}, {"r", ""}, {"H", ""}, {"I", ""}, {"p", ""}, {"M", ""}, {"S", ""}, {"V", ""}, {"Q", ""}, {"q", ""}}
set lp to {"Y", "y", "m", "B", "b", "d", "A", "a", "R", "r", "H", "I", "p", "M", "S", "V"}
set useShell to theDate = (current date)
considering case
--if theDate = (current date) then use shell script for all parameters in list lp
if useShell then
set v to ""
if theOffset is not "" then set v to " -v "
--convert theOffset in a format that is recognisable by shell script
set theShellPara to characters of theDateFormat
repeat with i from 1 to length of theShellPara
if theShellPara's item i is in lp then
set theShellPara's item i to "%" & theShellPara's item i
set theShellPara to "+" & theShellPara
-- get weeknum and adjusted date for computing Q and q
set (lol's item 16)'s item 2 to do shell script "date " & v & theOffset & " '+%V'"
set theDate to do shell script "date " & v & theOffset & " '+%d.%m.%Y %H:%M:%S'"
set theDate to date theDate
if "Q" is not in theDateFormat and "q" is not in theDateFormat then
set ds to do shell script "date " & v & theOffset & " " & quoted form of theShellPara
return ds
-- theDate is not current date then use date string computation
else
-- obtain the adjusted date (theDate+theOffset) calculation before formatting
set theOffset to (do shell script "[[ " & quoted form of theOffset & " =~ ([+-]+)([0-9]+)([A-Za-z]+) ]] && echo \"${BASH_REMATCH[1]},${BASH_REMATCH[2]},${BASH_REMATCH[3]}\"")
set {tid, text item delimiters} to {text item delimiters, ","}
set theOffset to every text item of theOffset
set text item delimiters to tid
set {offsetOperator, offsetMultiplier, offsetUnit} to theOffset
-- offsetBase in seconds. E.g. theOffset="+?d",offsetBase = 24*3600
set offsetBase to (my lolLookup(offsetUnit, 1, 2, ltd))'s item 2
if offsetUnit is in {"w", "d", "H", "M", "S"} then
-- standard date operation in AppleScript
set theDate to theDate + ((offsetOperator as string) & (offsetMultiplier as integer) * offsetBase)
else if offsetUnit is "y" then
-- +/- years
set theDate's year to (theDate's year) + ((offsetOperator as string) & (offsetMultiplier as integer) * 1)
else if offsetUnit is "m" then
-- tricky arithmatics
set {y, m} to {theDate's year, theDate's month as integer}
set yAdjustment to (m + ((offsetOperator as string) & (offsetMultiplier as integer) * 1)) div 12
set mAdjustment to (m + ((offsetOperator as string) & (offsetMultiplier as integer) * 1)) mod 12
if mAdjustment > 0 then
set y to y + yAdjustment
set m to mAdjustment
else
set y to y + yAdjustment - 1
set m to mAdjustment + 12
set {theDate's year, theDate's month} to {y, m}
tell theDate to set {y, m, ms, d, dw, h, n, s} to {its year as string, its month as integer, its month as string, its day as string, its weekday as string} & every word of its time string
-- get Y
set (lol's item 1)'s item 2 to y
-- get y
set (lol's item 2)'s item 2 to (characters 3 thru 4 of y as string)
-- get m
if m < 10 then -- m
set (lol's item 3)'s item 2 to "0" & m
else
set (lol's item 3)'s item 2 to m
-- get B
set (lol's item 4)'s item 2 to ms
-- get b
set (lol's item 5)'s item 2 to (characters 1 thru 3 of ms as string)
-- get d
set (lol's item 6)'s item 2 to d
-- get A
set (lol's item 7)'s item 2 to dw
-- get a
set (lol's item 8)'s item 2 to (characters 1 thru 3 of dw as string)
-- get R
set (lol's item 9)'s item 2 to h & ":" & n
set {t1, t2} to {h div 12, h mod 12} -- t1,t2 are temporary variables
if t1 ≥ 1 then
-- get p
set (lol's item 13)'s item 2 to "PM"
-- get r
set (lol's item 10)'s item 2 to ((h mod 12) & ":" & n & " PM")
else
-- get p
set (lol's item 13)'s item 2 to "AM"
-- get r
set (lol's item 10)'s item 2 to (h & ":" & n & " AM")
-- get H
set (lol's item 11)'s item 2 to h
-- get I
set (lol's item 12)'s item 2 to (h mod 12)
-- get M
set (lol's item 14)'s item 2 to n
-- get S
set (lol's item 15)'s item 2 to s
-- get V
--credit Nigel Garvey from macscripter.net for the script getISOWeekNumber ()
-- Comment from his script: ISO Standard: Weeks start on Mondays. A week that straddles a year boundarybelongs to the year in which it has more days. One consequence of this is that the "first week" of any year contains 4th January.
set aMonday to date "Monday, 3 January 2000 at 00:00:00"
set nextMonday to theDate - (theDate - aMonday) mod weeks + weeks
set Jan4 to date "Tuesday, 4 January 2000 at 00:00:00"
set Jan4's year to nextMonday's year
if (Jan4 does not come before nextMonday) then set Jan4's year to (Jan4's year) - 1
set baseMonday to Jan4 - (Jan4 - aMonday) mod weeks
set (lol's item 16)'s item 2 to (nextMonday - baseMonday) div weeks
-- end of Nigel's code for getISOWeekNumber()
set ds to ""
set theDateFormat to (every character of theDateFormat)
repeat with n from 1 to length of theDateFormat
if theDateFormat's item n is in lp then
set ds to ds & (my lolLookup(theDateFormat's item n, 1, 2, lol))'s item 2
else
set ds to ds & theDateFormat's item n
return ds
--get Q
--credit Nigel Garvey from macscripter.net for the script getdatesforweeknum()
-- Comment from his script: Assuming the ISO standard that the first week of the year is the one containing 4th January although that might begin in the previous calendar year.
tell theDate to set {y, m, d} to {its year, its month, its day}
set weekNum to (lol's item 16)'s item 2
set yearNum to y
set preferredWeekStart to "Mon"
set Jan4 to date "Tuesday, 4 January 2000 at 00:00:00" -- Or 4th January in any year after 1582.
set Jan4's year to yearNum -- Make that 4th January in the given year.
set baseMonday to date "Monday, 3 January 2000 at 00:00:00" -- Or any Monday in the past.
set baseWeekday to baseMonday + ((offset of (text 1 thru 2 of (preferredWeekStart as text)) in "MoTuWeThFrSaSu") div 2) * days
-- Derive the beginning of the week containing 4th January in the given year
set week1Start to Jan4 - (Jan4 - baseWeekday) mod weeks
-- and from that, the beginning of the weekNumth week.
set weekNStart to week1Start + (weekNum - 1) * weeks
set datesInWeek to {}
repeat with i from 0 to 6 * days by days
set {day:d, month:m, year:y} to weekNStart + i
tell y * 10000 + m * 100 + d as text
set end of datesInWeek to text 7 thru 8 & "." & text 5 thru 6 & "." & text 1 thru 4
set (lol's item 17)'s item 2 to datesInWeek
-- end of Nigel's code for getdatesforweeknum()
--get q
set datesNextSevenDays to {}
copy theDate to dte
set {day:d, month:m, year:y} to dte + i * days
set end of datesNextSevenDays to text 7 thru 8 & "." & text 5 thru 6 & "." & text 1 thru 4
set (lol's item 18)'s item 2 to datesNextSevenDays
if theDateFormat is "Q" then
return (lol's item 17)'s item 2
else if theDateFormat is "q" then
return (lol's item 18)'s item 2
end considering
end getDateStr
on lolLookup(lookupVal, lookUpPos, getValPos, theList)
--only for list of list with more than 1 items, and only return the first exact match
local i, j, k
set j to lookUpPos
set k to getValPos
repeat with i from 1 to length of theList
-- return (1) the index of the matched list in lol, (2) the specific item in the matched list, (3) the matched list
if (item j of item i of theList) is equal to lookupVal then return {i, item k of item i of theList, item i of theList}
return {0, "", {}}
end lolLookup
