Problem description: If you have searched this kind of question. You must have experienced that when you use some macos or some others softwares’ hotkey, you’ll find Devonthink 3 have coveraged these hotkeys/shortcuts with no permit.
e.g. when you want to use command+/ in Jetbrain’s IDE to comment current code. You’ll find that Devonthink3 always jump out to annoy you.
Here the solution: System Preference-Keyboard-shortcuts-services, and then turn off the command+/
Hi BeBubble,
I am sorry that you are angry. Please don’t degrade this support forum with vulgarity.
Thank you.
Rick
Changed the Expression
Hope devonthink 3 pro would do much better
Thank you
What do you propose as the alternative? The potential for keyboard conflicts is going to occur with any app that has system-wide Services. Fortunately, as you mentioned, the macOS offers the ability to change shortcuts to avoid said conflicts, which is pretty basic stuff.
