Well, what you want is a set that is the union of all the tags of the selection (minus the folder tags). Applescript doesn’t have any “canned” resources to support set functions on lists, but LateNight Software has a scripting addition that will:
if this_selection is {} then error "Please select some items."
set theTags to name of every parent of current database whose tag type is ordinary tag
set myTags to (choose from list theTags with multiple selections allowed)
repeat with this_item in this_selection
set theTags to tags of this_item
if exists tags of this_item then
set current_tags to the tags of this_item
set new_tags to current_tags & myTags
else
set new_tags to myTags
set the tags of this_item to new_tags
set taglist to name of every parent of current database whose tag type is ordinary tag
set theTags to simple_sort(taglist) of me
else
on simple_sort(my_list)
set the index_list to {}
set the sorted_list to {}
repeat (the number of items in my_list) times
set the low_item to ""
repeat with i from 1 to (number of items in my_list)
if i is not in the index_list then
set this_item to item i of my_list as text
if the low_item is "" then
set the low_item to this_item
set the low_item_index to i
else if this_item comes before the low_item then
set the end of sorted_list to the low_item
set the end of the index_list to the low_item_index
return the sorted_list
end simple_sort
@duende54498 I love using your script, and was wondering if it’s possible to modify it so that it lists all of the user’s tags from their databases (i.e., as opposed to only showing the tags that currently exist in the database where the file is located)?
I’ve tried adapting your script several times, but haven’t had any luck so far. Thanks for any help you can lend!
As I don’t work with multiple databases, I’m not really savvy on that topic.
You might try something like:
“set taglist to name of every parent of current database whose tag type is ordinary tag”
and then incorporate a subroutine to split the individual tag-names
or something similar
Good luck!
I tried several variations of the line you’ve listed above, and I think the following gets closest:
set taglist to name of every parent of every database whose tag type is ordinary tag
The output is pretty wonky, however - as it spits out a massive horizontal block of tags that all run together. As you can tell from this description, I’m a newbie! I suspect the issue is with the lack of a subroutine for splitting the tags out, as you note above. I’ll keep looking around and tinkering with the script, and let you know how it goes.
By chance, do you know of any good resources for scripting newbies that might deal with similar issues that I could learn from? As always, thanks for your help!
@duende54498 Thanks again for all of your help with everything. I was able to cobble your script together with a few others to get it working for all the databases at once.
In case you might find it useful, I’ve included it below. I’m sure there are more clean and efficient ways of combining the two subroutines, but this seems to work pretty well. As usual, all the usual caveats apply:
set theDatabases to databases
set theResults to {}
repeat with thisDatabase in theDatabases
set thisDatabasesResults to (name of every parent in thisDatabase whose tag type is ordinary tag)
set theResults to theResults & thisDatabasesResults
set taglistduplicates to theResults
set taglist to RemoveDuplicates(taglistduplicates) of me
else
end simple_sort
on RemoveDuplicates(inputList)
set outputList to {}
repeat with i from 1 to length of inputList
set thisItem to item i of inputList
set testItem to {thisItem}
if (outputList does not contain testItem) then
set end of outputList to thisItem
return outputList
end RemoveDuplicates
#Sources
#https://discourse.devontechnologies.com/t/a-tag-selector-akin-to-group-selector/9755/24
#https://macosxautomation.com/applescript/sbrt/sbrt-05.html
#https://discourse.devontechnologies.com/t/script-lookup-safari-url-in-open-databases/24989
#https://macscripter.net/viewtopic.php?id=8372
Here’s a revised script that uses the foundation framework to speed up sorting & filtering of tags (in case of hundreds or even thousands of tags this makes a huge difference):
use AppleScript version "2.4"
use framework "Foundation"
use scripting additions
set rawTags to {}
set thisDatabaseTags to (name of every parent in thisDatabase whose tag type is ordinary tag)
set rawTags to rawTags & thisDatabaseTags
tell current application's NSSet to set tagSet to setWithArray_(rawTags)
tell current application's NSSortDescriptor to set theDescriptor to sortDescriptorWithKey_ascending_(missing value, true)
set theTags to (tagSet's sortedArrayUsingDescriptors:{theDescriptor}) as list
set selectedTags to (choose from list theTags with multiple selections allowed)
set itemTags to the tags of this_item
set itemTags to itemTags & selectedTags
set the tags of this_item to itemTags
else
set the tags of this_item to selectedTags
