ACRONIS blocks Devon 4 installations
Since the release of Devonthink 4, I’ve been unable to due upgrades or clean installs. I finally found that Acronis, a widely used backup software, blocks the installation. Turning off protection inelegantly solves the problem. In more detail:
Acronis blocks installation, update, and deletion of a legitimate, notarized macOS application (DEVONthink 4, by DEVONtechnologies), because the app bundle contains a helper process in the standard Apple-documented Contents/Library/LoginItems/ folder. The block occurs even for an administrator account and even when running as root via sudo , indicating this is enforced at the kernel/Endpoint Security level rather than through standard file permissions.
A trouble report was filed with Acronis. The process in question block is labeled Active_Protect.
Thanks for the report. We contacted Acronis after being made aware of this false positive. It is up to them to affect this change.
Thanks. I agree, I just thought it might be of use to you. Always great support from your company.
You’re welcome and your encouragement is appreciated! And yeah, it’s an unfortunate situation. We had a similar incident with CleanMyMac about 5 years ago. Fortunately, that was resolved in fairly short order. I contacted Acronis on the 7th, so I’m hopeful it will be addressed soon.
We appreciate the patience.
