For a few years I successfully had a few Apple Mail rules automatically adding specific attachments to specific folders in DEVONthink. After the Yosemite upgrade it has mostly stopped working, although on occasions it suddenly works well for a few hours…
I adapted Christian’s original script - I have no real scripting knowledge - so no idea how to understand why it no longer works. If one of the exceptionally gifted scripting gurus could give me some suggestions I would be very grateful!
The script looks for some specific string in the attachment file name - and if it matches then adds to the database. The string is comprised of initials which are between two dots e.g. “.ab.” or “.cdg.” - is there any potential problem with that? a filename would be something like APT.cdg.INEX.Mar-15-2015
The mail rule is;
If ALL are true;
From ends with @xxx.com
Attachment type is PDF
Perform following action
Run Applescript
The script is as follows;
-- Mail Rule - Add attachments to DEVONthink Pro.
-- Created by Christian Grunenberg on Fri May 18 2012.
-- Copyright (c) 2012-2013. All rights reserved.
-- POSIX path of destination database
property pDatabasePath : "/Users/sps/Documents/Quotes.dtBase2"
using terms from application "Mail"
on perform mail action with messages theMessages for rule theRule
tell application "Mail"
set theFolder to (POSIX path of (path to temporary items))
repeat with theMessage in theMessages
set theSender to the sender of theMessage
repeat with theAttachment in mail attachments of theMessage
if (name of theAttachment) contains ".cr." then
set theFile to theFolder & (name of theAttachment)
tell theAttachment to save in theFile
set theGroup to get record with uuid "B65CB335-F0AC-4DE3-B0F1-C0EAA92663ED"
set theAttachmentRecord to import theFile to theGroup
set URL of theAttachmentRecord to theSender
else if (name of theAttachment) contains ".re." then
else if (name of theAttachment) contains ".cdg." then
else if (name of theAttachment) contains ".ab." then
end perform mail action with messages
end using terms from
