There is currently a function allowing us to ‘Set Title As’ (contextual menu). Would it be possible to have one allowing us to ‘Add to Comment’?
Thank you.
Thank you.
That’s easily scriptable:
activate
if not (exists think window 1) then error "No window open."
if not (exists content record) then error "No document selected."
set this_text to the selected text of think window 1 as string
if this_text is "" then error "No text selected."
set this_record to content record
set this_comment to comment of this_record as string
if this_comment is not "" then set this_comment to this_comment & return
set comment of this_record to (this_comment & this_text) as string
display alert "DEVONthink Pro" message error_message as warning
on error number error_number
if error_number is -1708 then display dialog error_message buttons {"OK"} default button 1
Just save this script in the folder ~/Library/Application Support/DEVONthink Pro.
