Hi,
Am trying to do a simple search, “term AND anotherTerm AND aThirdTerm”
But under the follow links it will only show OR.
So I am guessing that the actual search is using the three terms, but the follow links only allows OR.
thanks!
Hi,
thanks!
The automatic default term to follow links uses OR so that more links are followed. But this does not affect matching and you could of course specify your own term to follow links.
