Hello all,
I haven’t seen this posted before, so here’s an issue I’m encountering:
If you open a PDF into a new window, and begin annotation using either Note or Highlight, you can get some weird behavior. For example, if you create a note on one page, highlight on the next page (where the note isn’t visible) then the page jumps (zooms in) - and the creation of a note on the same page will zoom the page back out again to account for the note.
Direct replication:
- Open a multi-page PDF, maximize the window, and zoom in so the page fits the margins.
- Create a note on that page, the PDF zooms out some, but create space for the note on the left (this is expected).
- Scroll down to the next page (or til after the note is off the page) and highlight some random text.
- The behavior at this point is the space on the left is removed, and the page jumps back into the original place.
Settings (view -> PDF Display) checked:
- Single Pages
- Continuous
- Page Breaks
Version: 2.0pb7
