Any way to Read epub format within Devon?
I’ve a number of PDf’s I’ve converted to epub format for reading on my Nook, and I’d like to archive them using DevonThink, however I don’t see that it can read it. All I’m getting is a icon.
Is there something I need to do in order to get the epub to work with DevonThink? :question:
DEVONthink relies on QuickLook plugins to display most document types apart from .txt, .rtf or .pdf. I’m not sure if there is an ePub QuickLook plugin available, but if there is then it would need to be installed on your computer before DEVONthink could show previews for your documents.
Generally, if you can preview a document in Finder then you can preview it in DEVONthink.
