Appending Rich Note shortcut
Hi
I have tried to search the forums for an answer to if one can set a keyboard shortcut for appending rich note and if so how to do it. I have as yet not found one. Can perhaps someone help me or give me a pointer?
Thanks
The best solution I have found is Service Scrubber, which allows you to set Service menu item shortcuts and much more. It is available as donationware here:
petermaurer.de/nasi.php?sect … cescrubber
Great software … thanks for the tip just what I needed!
