Hi,
Is there an easy way set up a group so that it to automatically replicates its contents to another group - apart from replicating the group itself?
Thanks!
Hi,
Thanks!
Do you mean to automatically replicate to another group whenever a new file is added to the first group? Are you indexing folders or not?
Yes, exactly.
No, not indexing. Unless there’s a way to index email messages in DTP.
You do NOT want to go messing about with this. Technically possible, but not a good exeprience.
Ok. So noted. Leaving aside the content of the files, is there a way set up a group so that it to automatically replicates its contents to another group - apart from replicating the group itself? Thanks.
No, replicating the group is the only workaround.
Ok, thanks so much. Was just seeking an alternative for organizational purposes. Anyway, thanks for all of your help & feedback. Appreciate it.
