Yes, that was the title of my post. I even turned it off and back on, just in case. I assume you don’t see this behavior? It’s only since installing 4.4.2. It worked beautifully prior to this version.
I was wondering why the Unread numbers in the sidebar weren’t going down as I viewed them. Lately, all of my Clip to DEVONthink items are bookmarks. None of them were changing from Unread to Read.
I did some testing on several files which included .webloc, .md, .eml, .rtf, .png files, etc. All except the .webloc files changed from Unread to Read.
Now, as I’ve fine-tuned how I use DEVONthink, since installing 4.4.2, I have made some changes in the Settings. The only one I actually remember is the WYSIWYG setting in Markdown. I turned that off and tested again. Bookmarks still don’t change to Read status.
Just remembered another setting. I had turned off Files | Preview | General | Automatically load bookmarks. I turned that back on. Viola! Bookmarks now change to Read status.
So now the question is, should a bookmark be considered Unread unless it’s loaded? I like just seeing the preview of the bookmark instead of the webpage automatically loading.
Now, even though I’ve now discovered why the bookmarks weren’t changing to Read status, I see another problem, well, to me anyway.
With Files | Preview | General | Automatically load bookmarks turned Off, I have the option to Load Preview. That’s fine, works good. However, once the bookmark is loaded, shouldn’t the bookmark change to Read status? It’s still shown as Unread.
But that still isn’t what I would prefer. I would prefer that the bookmark be shown as Read by clicking on it, whether the webpage is loaded or not.
Since I’ve been using DEVONthink for a long time, and I’ve never turned Off Files | Preview | General | Automatically load bookmarks before now, perhaps this has always been the case that a bookmark’s Unread/Read status doesn’t change to Read with this setting Off. I’m just noticing, but everyone else likes it this way. I just find it quirky, especially since it doesn’t change to Read after I’ve actually loaded the bookmark, viewed the whole page, and it still shows as Unread.
