B2 does not connect
Just downloaded B2 this evening. Works fine it just doesn’t seem to be aware of the internet connection. When a search is made a brief initialization is done then its over and nothing is found. B1 works fine. Tried searching various areas such as googlism, internet, etc with the same results.
As downloading has not been modified in beta 2, try to delete your preferences.
