Added a new custom meta data, then tried to apply “Tools - Batch Process”. The problem is that I can’t find this new meta data in the drop-down list… Restarted DT, restarted MBP finally - nothing…
Any thoughts?
Custom metadata is listed at the bottom of the actions. However it also depends on what data type the attribute is.
Oops, didn’t know that “Identifier” type is not eligible for batch processing. Changed it to “Single line text” - all works now as intended!
Thanks
You’re welcome
