I took some time and refined the script a bit and like to share this one as well. This one also works on already imported items.
The script
- adds the name to the aliases
- adds the sender domain to the name
- adds the subject to the (finder) comments
- checks “Exclude from … Wiki Linking”
- stores the message id (link) in the URL field
Please note: If the corresponding mail is not selected when the script is run it searches all mailboxes for the mail. I don’t know how this behaves with huge mailboxes and I only tested it with Mail 16/macOS 13.7.1 …
Edit: changed “do shell script” to work on macOS 14.7.1
on getMessageId(theOriginMessageId)
tell application "Mail"
set theSelection to selection
repeat with theMessage in theSelection
if id of theMessage as integer is theOriginMessageId as integer then exit repeat
if id of theMessage as integer is not theOriginMessageId as integer then error
on error
repeat with theMessage in (every message of every mailbox of every account whose id is theOriginMessageId)
on error
repeat with theMessage in (every message of every mailbox whose id is theOriginMessageId)
return message id of theMessage
end getMessageId
set {theOriginSenderHandle, theOriginSubject, theOriginMessageId} to paragraphs of (do shell script ¬
"/bin/bash -c \"mdimport -d3 -t -n '" & path of theRecord & "' | awk '/com.apple.synapse/{next} /\\{/{a=1}/\\}/{print;a=0}a' | tee >(plutil -extract \":PR:kMDItemOriginMessageID\" raw -) >(plutil -extract \":PR:kMDItemOriginSubject\" raw -) >(plutil -extract \":PR:kMDItemOriginSenderHandle\" raw -) >/dev/null\"")
set theOriginMessageId to theOriginMessageId as integer
set isAttachment to true
on error
set isAttachment to false
if isAttachment then
set theOriginSenderDomain to " @" & (do shell script "echo '" & theOriginSenderHandle & "'| awk -F '@|>' '{print $2}'")
set theAliases to aliases of theRecord
set AppleScript's text item delimiters to ";"
set theAliases to text items of theAliases
if theAliases does not contain name of theRecord then
copy name of theRecord to end of theAliases
set aliases of theRecord to theAliases as text
set exclude from Wiki linking of theRecord to true
if name of theRecord does not end with theOriginSenderDomain then ¬
set name of theRecord to name of theRecord & theOriginSenderDomain
if comment of theRecord does not contain theOriginSubject then
if comment of theRecord = "" then
set comment of theRecord to "Subject: " & theOriginSubject
else
set comment of theRecord to comment of theRecord & return & "Subject: " & theOriginSubject
set URL of theRecord to "message://" & "%3c" & my getMessageId(theOriginMessageId) & "%3e"
end performSmartRule
