I like the smart folder options however, they are almost good enough, which can be frustrating.
Can you add the option to name them with other than the search terms?
Can you add “is/is not” options for words in the same group?
thanks
thanks
Why not just rename the Smart Group after it’s created?
What I’m really lacking is a visual representation of which groups have scripts attached to them and/or a way to search for such groups. One concern is a script’s location changing without having any way to know which DT groups are affected so they can be updated with the new location.
