Using DEVONthink Pro 2.9.12 and DEVONthink To Go 2.1.6 CSS for Markdown goes somehow wrong:
When creating a Markdown document like this:
<link href="bodyserif.css" rel="stylesheet" type="text/css">
# Body styled with a serif font
This body text should be in Serif (Garamond): Lorem ipsum dolor sit amet [...]
with the following CSS file bodyserif.css in the same group:
body
font-family: Garamond, Georgia, serif;
font-size: 18px;
I get the following rendering on macOS:
That is as expected; however on iOS (iPad) I see the following:
Why? From my understanding the body should display in Garamond, or at least in a system serif font. Does DEVONthink To Go not generate a body tag for its HTML rendering? Any idea how can I write a workaround CSS which works on macOS and on iOS?
What kind of link do you use to reference the stylesheet? Due to limitations/bugs of v2.9.12 not all links work as expected, the upcoming v2.9.13 will fix this.
Hi,
I currently have 2.1.7 but the above example doesn’t seem to be working for me in DTTG, only DTPO. Based on the release notes I take it that “Fixed an issue where the styles of the BODY tag of a rendered Markdown document couldn’t be changed.” was referring to this issue, so is this just a problem for me? Any luck halloleo?
