I installed DT3beta1 in a completely new account (fresh install). Directly after installation the smart rules were shown in the sidebar. After closing and re-starting DT3beta1 all of them disappeared. I have done no other action in DT3beta1. Why do the smart rules disappear. Is this a known bug? May @BLUEFROG or @cgrunenberg comment on this? How to get the smart rules back?
fresh account on my computer, fresh installation of DT3beta1. I installed it, activated it. I saw the standard smart rules. I closed DT3 and started it again. All smart rules disappeared. As you can see in the screenshots above. I did not do anything else (just close and re-start the app). Why did they disappear? How to get them back?
@BLUEFROG@anubis I had the same issue before on another account, when installing DT3 in the same account with an existing DT2 installation. So I thought it was a problem with having both apps in the same account. Now I installed it in a completely new account, without any other DT installation, and the same happened. Is this a bug, as also @anubis experienced the same problem, see above? How to get the standard smart rules back?
New user account, no previous DT installation. Fresh DT3beta 1 installation.
All smart rules were showing directly after installation of DT3beta1. I just closed the app and started it again (without opening any database etc). At second start of DT3beta1 all smartrules had disappeared.
If this is a bug, please fix it with beta2. @cgrunenberg
Is there any way to manually re-import the standard smart rules of DT3beta1 (can you upload the according file here and let me know where to place it in the finder to get the standard DT3beta1 smart rules back?)
Existing DT pro 2 paid user.
Just downloaded DT3 and juggling with it since half a day with my DT2 bases.
Not paid DT3 upgrade yet but will (love it: general inbox + UI + inspector).
I completely uninstalled DT2 and DT3beta1 from my computer / old account according to this:
UNINSTALLING DT2
To remove (uninstall) DEVONthink Pro Office completely from your Mac, trash the following files and folders (~ stands for your Home folder): DEVONthink Pro Office ~/Library/Application Support/DEVONthink Pro 2 ~/Library/Mail/Bundles/DEVONthink.mailbundle ~/Library/Preferences/com.devon-technologies.thinkpro.* All DEVONthink Pro Office-specific scripts in ~/Library/Scripts/ All DEVONthink Pro Office-specific workflows in ~/Library/Workflows/ All DEVONthink Pro Office-specific scripts in ~/Library/PDF Services/ Dashboard widgets Bookmarklets from your web browser The reference to the global inbox folder in your Finder’s sidebar Keychain entries containing “devoncloudy”
UNINSTALLING DT3
If for some reason you need to fully uninstall DEVONthink from your Mac, trash the following files and folders (~ stands for your account’s home folder):
All DEVONthink-specific scripts in ~/Library/Scripts
All DEVONthink-specific workflows in ~/Library/Workflows/
All DEVONthink-specific scripts in ~/Library/PDF Services/
Uninstall the DEVONthink browser extension, following the uninstallation process for the particular browser.
Keychain entries containing devoncloudy in the name
I created a new ADMINISTRATOR ACCOUNT
I provided full disk access to DT3beta1
I started DT3beta1 --> all smart rules were shown
I closed DT3beta1 (without doing anything else before, I did not open any previous database etc)
I started DT3beta1 --> no smart rules were shown
–> Why were the smart rules deleted after second start? If this is a bug, do not hesitate to ask me for further information if needed.
–> Is there any manual way to re-import them?
–> If yes, could you please upload the according file here: ** !!! German (!!!) version of standard DT3beta1 Pro smart rules !!!
** and let me know, where I should save it in the finder (I assume library > application support > devonthink3 folder)?
there is a smartgroups.plist but NO smartrules.plist
if you can not reproduce the issue, it will be difficult to solve this potential bug?
is there at least a possibility to help me to provide me the German (!) version of the smartrules.plist file of DT3beta1 Pro? So I could copy it to the appropriate application support folder?
Criss will have to weigh in on this, but it’s certainly an unusual bug since the file itself is missing. That makes little technical sense, just on the face of it.
Try unzipping this and putting it in the ~/Library/Application Support/DEVONthink 3 directory. The relaunch, quit, and relaunch DEVONthink 3.
no, as I see that the strings in the source code of the smartrules.plist is in English, I would kindly ask you to upload the German version of it, in order to allow better consistency in my DT3beta1 installation, which is in German. Or should I change the string names in the plist code before copying it to the application support folder?
You have to delete both the SmartRules.plist file in application support and reset the preferences. Beta 2 will fix the bug (and deleting the file will be sufficient to get the defaults again too).
