Hi. I bought Devon Agent Pro in Stacksocial and it seems to be locked in the “building script menu” message. The rest of the program is functional. The abbreviated search in menu bar, the options, including I have registered the license. But the main window does not appear. I use mac os Catalina. I thought DevonAgent was ready. I also have the latest DevonThink 3 beta active on the desktop.
Remeber: macOS 10.15 is a beta operating system. Unless you are explicitly beta testing and reporting, you should not run a beta operating system on a device you need operating as expected.
