Hello. I’ve coped my three databases (1.2 GB, 11.2 GB, 1 GB) over to my new MBP. After opening the 11.2, it has stalled on a single file while "Calculating Checksums.” The bar has been at 25% across for over three hours.
So it occurred to me that maybe I’m relocating my databases on my new machine the wrong way. I simply put them inside the Databases folder that DTP makes when you first launch it, and then double-clicked on them.
Is there another way to migrate that won’t cause DTP to work so hard? Should I have copied all the DTP stuff in my ~/Library folder as well? Should I force quit and do so?
My HDD has the same name, and all indexed items have the same paths. Thanks in advance.
