Can I tag and group specific passages for process tracing?
I’m trying to use DEVONthink to organize a ton of archival documents for process tracing, and I’m wondering what the closest workable approximation is to passage-level tagging.
Ideally, as I go through each document, I’d like to mark specific selections as evidence for a particular mechanism, variable, causal step, etc. Then I’d like to be able to use smart groups or some similar system to gather all documents/passages tagged with a given mechanism or variable. Best case, when I select an item in that group, it would take me directly to the relevant passage in the document.
I know DEVONthink does not really support tags on specific text selections, nor does it seem to provide robust deep links to exact passages within documents. So I’m trying to figure out the best practical workaround. Using Zotero for annotating is an option, but feels redundant, and like I’m not making the most of DT’s capabilities.
For those of you who use DEVONthink for qualitative research, archival work, or process tracing, how would you approximate this workflow?
Thanks y’all!
Welcome @Mevers90
Sure it does. You can make paragraph or selection links in several file formats, e.g., rich text or PDF documents. This is documented at the end of each section in the Documents chapter of the built-in Help and manual.
You can’t use a smart group to gather passages unless they were independent documents.
Also, you’re describing or imagining a system, not a feature. Would it be possible to create some kind of closed loop with DEVONthink’s robust automation technologies? It’s likely some useful core could be built. But there’s definitely not something so specific built into the app.
My apologies I mispoke. You’re right that I can create deep links to passages and copy them into a markdown file. I’m looking for something more automated, as you mentioned. For instance, if there was a script that could run through all the .pdfs and create a markdown file with every annotation associated with a specific highlight (e.g. the highlighted text, file name, etc.) Presumably, I could make different markdown files for different kinds of highligths. I’m not technically inclined so I have no idea where to begin or even what to search for :slight_smile:
No worries!
If you add an annotation to a file, e.g., a PDF document, you can add a note in the Details section of the Document > Annotations inspector. You can actually use this as a pseudo-tagging mechanism.
You can use Tools > Summarize Annotations to create a new document containing all the annotations in selected documents.
They are segregated by page, not color or type. However, you will also see the details are listed below the passage.
You can also search the summary document via the Search inspector…
