If I pull up an object using the DT web interface that contains extensive comments, I noticed that it doesn’t put a scroll bar in the web pane that contains the comment. It will just cut it off. Of course, you can resize the the pane (frame I guess), but if it’s still too large, it will cut it off. Any ideas?
