Hello all,
Here’s a script I use to capture the front document of whatever app I am using and put it into a PDF in devonthink. Right now it works mostly with browsers (camino, safari, devonagent, etc.) and pdf readers (skim, pdfpenpro, and (kind of ) preview.app). I set this script to a hotkey and it will try to figure out whether I’m browsing or editing a pdf, looking a a web page, etc, and do the right thing. As a bonus, if the pdf is not already ocr-ed it will do that too. Great for using jstor or the like. More applications can be added pretty easily if you can tell me your usage. Hopefully you will find the script handy…
erico
---- PDF-Archive current document
----version 1.1c by Eric Oberle
----This script attempts to detect which program is currently the frontmost, and attempts to send a pdf of that document to Devonthink Pro. The goal of the script is to allow you to have a single key to archive all files.
--it is best used with a "hot key" program, such as red sweater software's "Fastscripts"
----it should work with Preview.app (most of the time), Skim, Pdfpenpro for pdfs, and it should work with DevonAgent, Safari, Omniweb, Camino, Firefox, and Opera. If any one of these browsers has a webpage open instead of a pdf, the script will attempt to make a pdf out of that webpage.
---the script currently expects that you have installed growl.
---note: if there are some of these browsers that you would never use, feel free to comment out that code block by enclosing it with (* *). Otherwise applescript editors will open them whenever you try to edit this script.
property app_to_use_if_in_script_editor : "Skim"
property use_growl : true
----figure out which program is frontmost
set front_prog to displayed name of first process whose frontmost is true
set front_prog to front_prog as string
set insert_location to incoming_group
on error
set cur_sel to selection
set insert_location to parent of cur_sel
on error
set insert_location to incoming group
--set insert_location to root of database 1
set the_Window to window 1
set insert_location_string to name of insert_location
----This variable is set above to ease debugging.
if front_prog contains "Script" then set front_prog to app_to_use_if_in_script_editor
---Do the right thing to create the PDF
if (front_prog contains "Safari") or (front_prog contains "WebKit") then
using terms from application "Safari"
tell application front_prog
if not (exists document 1) then error front_prog & " seems to have no document open."
set the_url to the URL of document 1
set the_title to the name of window 1
get source of document 1
set the_source to result
on error message
log message
set the_source to "PDF"
end using terms from
my create_pdf(the_source, the_title, the_url, "", insert_location, true)
else if (front_prog contains "DEVONthink") then
set the_url to the URL of the_Window
set the_title to the name of the_Window
set the_source to source of the_Window
if the_source is not "" then set the_title to get title of the_source
set pdf_content to get paginated PDF of the_Window
set new_pdf to create record with {type:picture, URL:the_url, name:the_title}
set data of new_pdf to pdf_content
my growl_notify("Completed", "PDF filed", the_title & " to " & insert_location_string, true)
else if (front_prog contains "DevonAgent") then
tell application "DEVONagent"
if not (exists browser 1) then error "DevonAgent seems to have no document open"
set this_url to the URL of browser 1
set this_title to the name of window 1
set this_source to the source of window 1
my growl_notify("Completed", "PDF filed", the_title, true)
else if front_prog contains "Camino" then
using terms from application "Camino"
tell application "Camino"
set the_url to URL of browser window 1
set the_name to name of browser window 1
my create_pdf("", the_name, the_url, "", insert_location, true)
else if front_prog contains "firefox-bin" then
using terms from application "Firefox"
tell application "Firefox"
set the_name to «class pTit» of window 1
set the_url to «class curl» of window 1
else if front_prog contains "Opera" then
using terms from application "Opera"
tell application "Opera"
set myInfo to GetWindowInfo of window 1
set the_url to item 1 of myInfo
set the_name to item 2 of my info
(* else if front_prog contains "NetNews" then
using terms from application "NetNewsWire"
tell application "NetNewsWire"
set tab_num to index of selected tab
if (tab_num is greater than 0) then
set some_urls to URLs of tabs
set the_url to item (tab_num + 1) of some_urls
set tab_titles to titles of tabs
set the_title to item (tab_num + 1) of tab_titles
else
set the_url to get URL of selectedHeadline
if the_url is "" then error "Please make sure you have a web page in view in Netnewswire"
end using terms from *)
else if front_prog contains "Vienna" then
tell application "Vienna"
set the_url to link of current article
set the_name to title of current article
set the_source to documentHTMLSource
my create_pdf(the_source, the_name, the_url, "", insert_location, true)
else if front_prog contains "OmniWeb" then
using terms from application "OmniWeb"
tell application "OmniWeb"
if not (exists browser 1) then error "No browser is open."
set the_url to get address of active tab of browser 1
set the_name to get name of browser 1
set this_source to do script "document.body.innerHTML" window browser 1
else if front_prog contains "PDFPen" then
set the_path to path of document 1
set the_name to name of document 1
my create_pdf("PDF", the_name, "", the_path & " to " & insert_location_string, insert_location, true)
else if front_prog contains "Skim" then
set the_document to document of window 1
set the_path to path of the_document
set the_name to name of the_document
my create_pdf(the_source, the_name, "", the_path, insert_location, true)
(* Disabled because Acrobat 9 applescript is broken
else if front_prog contains "Acrobat Pro" then
using terms from application "Adobe Acrobat Pro"
set the_document to document 1
set myScript to "this.saveAs(\"/var/tmp/" & the_name & ".pdf\",
\"com.adobe.acrobat.pdf\");" as string
do script myScript
---set save_alias to POSIX file "/var/tmp" & the_name
---save the_document to save_alias
set the_path to ("/var/tmp/" & the_name)
else if front_prog contains "Preview" then
----this block of code makes the Preview.app program scriptable
---it is a hack, but seems to work. Thanks to Daniel Jalkut
---http://www.red-sweater.com/blog/150/minimal-scriptability
set the_result to ""
tell application "Finder"
set the Preview_app to (application file id "com.apple.Preview") as alias
set the plist_filepath to the quoted form of ((POSIX path of the Preview_app) & "Contents/Info")
set the_script to "defaults read " & the plist_filepath & space & "NSAppleScriptEnabled 2>&1"
set the_result to do shell script the_script
on error the_result
set the_result to the_result
if the_result contains "does not exist" then
log (do shell script "defaults write " & the plist_filepath & space & "NSAppleScriptEnabled -bool YES")
my growl_quick("I just attempted to make Preview.app scriptable. You might need to quit that program and start it again in order for this to work.")
---gets all windows
tell application "Preview"
set preview_docs to {}
repeat with this_win in windows
set end of preview_docs to document of this_win
repeat with thisDoc in preview_docs
set the_name to "unknown document"
set the_name to name of thisDoc
set the_path to POSIX file (path of thisDoc) as Unicode text
else
activate
display dialog "I'm sorry this script does not know how to handle application " & (front_prog as string)
on create_pdf(the_source, the_name, the_url, the_path, insert_location, notify)
log "path = " & the_path
if the_source = "PDF" and the_path is not "" then
with timeout of 200000 seconds
set new_pdf to import (POSIX path of the_path) to insert_location type "PDF"
if kind of new_pdf is not "PDF+Text" then
convert image record new_pdf
end timeout
else ---here all cases where we have to download something
if the_source is not equal to "PDF" and the_url is not equal to "" then
set temp_page to create record with {type:bookmark, URL:the_url, source:the_source}
else
with timeout of 4000 seconds
set pdf_data to download URL the_url
end timeout
set temp_page to create record with {type:picture, URL:the_url}
set data of temp_page to pdf_data
log the_source
log the_url
set the_Window to open window for record temp_page
set visible of the_Window to false
repeat while loading of the_Window
delay 1
with timeout of 20000 seconds
if the_name is "" then set the_name to get name of the_Window
set new_pdf to create record with {type:picture, URL:the_url, name:the_name}
-- my growl_notify("Completed", "PDF filed", the_name, true)
close the_Window
delete record temp_page
end timeout
if notify is true then
my growl_initialize
my growl_notify("Completed", "PDF filed", the_name, use_growl)
return new_pdf
end create_pdf
on growl_initialize()
tell application "GrowlHelperApp"
-- Make a list of all the notification types
-- that this script will ever send:
set the allNotificationsList to ¬
{"Starting", "Completed"}
set the enabledNotificationsList to ¬
register as application ¬
"Devonthink Scripting" all notifications allNotificationsList ¬
default notifications enabledNotificationsList ¬
icon of application "Devonthink Pro"
end growl_initialize
on growl_notify(notification_type, the_title, the_message)
if notification_type is "Completed" then
notify with name ¬
"Completed" title ¬
the_title description ¬
the_message application name "Devonthink Scripting"
else
notify with name ¬
"Starting" title ¬
end growl_notify
on growl_quick(the_message)
my growl_notify("Generic", "Attention:", the_message)
end growl_quick
note: safari bug fixed 10/26
