Surely, saving links as bookmarks underneath the opened web archive is not bad. But if you want it there as a web archive you have to open the bookmark and save it as web archive. Especially if you’re picking just a dozen of links to be saved that way and the Download feature is an overkill for what you need.
Thanks, BlueFrog. In general, I once thought of rules as well, both for batch post-processing or one-by-one.
What I actually mean is that simply reflecting the web clipper options for Safari on the internal browser’s context menu would save a bit of work. If that’s not a bunch of coding for a future update. There are workflows where I sometimes find myself using DT as a browser too and end up collecting tabs and bookmarks for saving them later in different ways.
I’m not sure I follow, but it’s already possible to use Clip to DEVONthink inside DEVONthink. It’s in the Action menu in the Navigation bar.
Actually, the context menu for links inside a web page . . . when seen in the internal DT browser, instead of “Capture Link”.
Development would have to assess the feasibility of this.
