I was viewing a .webarchive file in my DEVONthink database earlier today and while scrolling through the page, I right clicked and saw ‘Capture Page’.
Is it possible to bring this right click ‘capture page’ feature into the contextual menu?
I installed the ‘Clip to DEVONthink 1.2.2’ Safari add-on but it only appears in the Right Click --> Services contextual menu, and it doesn’t have the ‘capture page’ feature.
If you saw the Capture page contextual menu option (as shown in your screenshot) you had right-clicked in the pane displaying the content of the WebArchive document already captured into your database. It’s already in the contextual menu options for that context.
You will also see a related contextual menu option, to update the captured WebArchive to the current version that’s displayed online.
If, instead, you had right-clicked on the Name of the document in a view window, the context is different and you won’t see the Capture page contextual menu or update options.
Also, you can get the Bookmarklet and invoke it via a Command key, depending on it’s order from left to right in the Bookmarks bar. For example, if PDF the first item in the Bookmarks bar, pressing Command-1 will create a PDF of the current page in DEVONthink.
Yep, I love how the settings are ‘sticky’ (don’t change after I set it), so that I can just press +Shift+C and then +S afterwards to get it sent to DEVONthink.
