Is there a way to change the font of multiple existing rich text notes? Somehow they imported as (I think) system font, but I would like them to all be Calibri.
Thanks!
Thanks!
You imported them from where?
The defaults for the future rich text files can be set via Preferences > Editing > Rich Text & Note Font.
The imported notes are RTF documents exported from Bear. I guess I’ll just change the manually as I come across them. Thanks!
No problem.
