Color section not showing in Inspector panel
I am trying to color my tags but for some reason the color section isn’t showing in my inspector panel. I have tried preferences setting modern and dots.
Is there anything else I have to check?
Running latest version of DTPO.
You will have seen this blogpost on colouring your tags. I suspect you have skipped the second item on the list. Your screenshot is of inspector showing details of a record rather than of a tag.
Thanks Blanc. You are right.
