Hi, just wanted to share something I built and might be of interest.
Scenario
I sometimes write minutes of meetings that address confidential topics, which are sent by e-mail to every attendee as a PDF attachment. Leakage of this information could have an adverse impact on the company, so some actions must be taken to reasonably keep these minutes as secure as possible.
I write my minutes in markdown.
Goal
The goal is to watermark the minutes with a big CONFIDENTIAL sign, and also add the name of the attendee to the watermark, to put further pressure on the recipients.
Problems
There are over 10 attendees, so printing the minute as PDF, then editing duplicates to set up the “CONFIDENTIAL” sign on each page, and then sending the right PDF to each attendee, is very time consuming.
Solution
- Use DEVONthink Pro capabilities to duplicate the PDF file, change the file name, and imprint the personalized “CONFIDENTIAL” sign + the name of the recipient.
- Use Applescript to automate the process and send the emails.
if (count of theSelection) is 1 then
set theRecord to the content record
set recordType to (type of theRecord as string)
if (recordType = "PDF document") then
set myList to {{|assistantName|:"First attendee", assistantEMail:"some@email.com"}, {|assistantName|:"Second Attendee", assistantEMail:"other@email.com"}, {|assistantName|:"Third", assistantEMail:"another@email.com"}}
repeat with theItem in myList
set originalName to the name without extension of the theRecord
set newRecord to duplicate record theRecord to the current group
set newRecordAssistantEmail to assistantEMail of theItem
set newRecordAssistantName to assistantName of theItem
set newRecordName to originalName & " - " & newRecordAssistantName as text
set name of newRecord to newRecordName
set newRecordPath to path of newRecord
set myText to "CONFIDENTIAL
imprint font "Times New Roman Italic" foreground color {50000, 50000, 50000} position center rotation 65 record newRecord size 80 text myText with outlined -- Add here some formatting
delay 1
-- Mail
tell application "Mail"
set theFrom to "my@email.com"
set theTos to {newRecordAssistantEmail}
set theCcs to {}
set theBccs to {}
set theSubject to newRecordName
set theContent to ""
set theMessage to make new outgoing message with properties {sender:theFrom, subject:theSubject, content:theContent, visible:false}
tell theMessage
repeat with theTo in theTos
make new recipient at end of to recipients with properties {address:theTo}
repeat with theCc in theCcs
make new cc recipient at end of cc recipients with properties {address:theCc}
repeat with theBcc in theBccs
make new bcc recipient at end of bcc recipients with properties {address:theBcc}
make new attachment with properties {file name:newRecordPath} at after last paragraph
delay 1
send
--- END MAIL
return true
else
return "Select PDF file"
else
return "Select one PDF file"
How-To
- Edit the script with the attendee’s names, emails, and the email of the sender (In this case, myself)
- Add the PDF of the minute to DT
- Run the script
- You’ll get one PDF duplicate for each attendee. I prefer to manually delete them, but you may want to add a delete step to the script, should be fairly easy
Result
- It works like a charm
- I link to the posts where most of the code came from, thank you @DTLow , @Igor_B and of course @BLUEFROG
Keywords
- IMPRINTER
- MINUTES
- CONFIDENTIAL INFORMATION
- EMAIL AUTOMATION
