BackBlaze.
Me too, almost exactly, except I use SuperDuper! instead of CCC. However, I deem this to be not enough backup, so I also use ARQ to make copies to an Amazon S3 bucket, and I use the Export Db script to make a zip file and have that zip file copied to an external drive; in addition to occasionally exporting my data onto flash drives.
I’m still having trouble getting the export script to run from a DT3 reminder.
The embedded script only has “Open Document” and I can’t do anything other than select that.
Reminder script are located in the ~/Library/Application Scripts/com.devon-technologies.think3/Reminders directory.
See Help > Documentation > Automation > Reminder Scripts, bearing in mind there is no backup script there at this time.
Okay, I understand now. You have to put a script in that location before it’s available to the reminders.
Okay, so, I copied the Daily Backup Archive script to the Reminders folder, restarted DT3, and was able to find it for use in a reminder. I set it up and it ran (got the notification), but it created no backup file in Backups.
Will that script work like this or does it need to be modified?
As noted in the documentation I referred to, you need to use the on performReminder handler.
What are you intending to set the Reminder on?
To just give another option: I make monthly backups by…
- saving the the database-file to a .dmg
- copying that .dmg to a external drive
- uploading that .dmg to SpiderOak
So than I both have a backup on an external drive (locked in my safe) and a downloadable .dmg via SpiderOak. It’s a low tech way of saving backups, but it works fine.
I want to trigger the Daily backup archive.scpt to run from a DT3 reminder.
I don’t do AppleScript, so looking in the document section called “Terminology” would not have been the place I’d look for info on setting up a reminder script.
In the documentation example, the script begins with on performReminder(theRecord) but would that be what I’d want here, as the script should run on the database. Again, no experience with AppleScript.
At the risk of veering slightly off topic, for which my apologies, would forum members recommend Are over BackBlaze? TIA!
I used both Backblaze Personal and Arq in the past, but stopped using Backblaze recently.
They were always very political in what they didn’t back up (Finder tags…), but given their low pricing I kept using the product in addition to Arq (I would never have been comfortable with Backblaze as my main remote backup). Due to missteps stacking up over the last 12 months or so, I canceled my subscription.
The main issues bothering me are related to security & software quality and their politcal stance against backing up metadata. You can find their developers on Reddit saying noone should use tags for instance and just name files differently and use strict folder structures.
Some links…
My other concern is that Backblaze doesn’t actually back up everything. It fails all but one of the Backup Bouncer tests, discarding file permissions, symlinks, Finder flags and locks, creation dates (despite claims), modification date (timezone-shifted), extended attributes (which include Finder tags and the “where from” URL), and Finder comments. (Source)
(Source)
Thanks, Chris - that’s extremely helpful!
I think I know what I have to do now
did you consider, or has anybody else used Chronosync for this? Is Chronosync equally effective as Arq? I suppose depends on whether it uses a snapshot-style backup and Chronosync does have an option in its backup options and I have enabled that option. From Chronosync options description:
Freeze file system - If snapshots are supported and this option is turned ON, a snapshot of your file system will be taken before running the task and then used as your source target.
While I did purchase Arq, and have used it, I would rather not have the Arq files at the other end.
Thank you.
This is an old post but perhaps a word of warning…
Thank you. That makes sense. However, I am only trying to backup to a network drive. So the question for me is if Arq can work then shouldn’t Chronosync also?
A bit of programming help. I have been able to set the Daily backup script to write to a Dropbox folder and to an external hard drive separately. I would like to do it simultaneously but I must be missing something simple to make both happen (like an AND command between, I guess).
set this_archive to “~/Dropbox/MyAppsWorkFile/DevonDailyBackup2022/” & this_name & " " & this_date & “.dtBase2.zip”
set this_archive to “Volumes/Store/Backup DEVON/DevonDailyBackup2022/” & this_name & " " & this_date & “.dtBase2.zip”
Thanks for your attention to this matter.
You are setting the same variable twice in this code. I guess that you might want to perform the act of archiving first before changing the variable’s name.
Edit: I also suspect that there’s a typo in the second set: It probably should be “/Volumes…” with a leading slash.
After having a look at the script itself: If you want to save to two different locations, you might want to refactor the part starting from the set timeout line until the end of the save proper into its own subroutine (that might be called a handler in AppleScript, but I’m not sure). Pass in the target name (this_archive) as a parameter and call it twice: once after the first set this_archive, once after the second.
thank you @chrillek Yes, the variable is set twice because I would like to make the same backup to two locations. The second set works without the “/”. Don’t know what is to “refactor” but yes, having a timeout between them seems logical. I did not understand anything of what you mean from here: " until the end of the save proper into its own subroutine (that might be called a handler in AppleScript, but I’m not sure). Pass in the target name (this_archive ) as a parameter and call it twice: once after the first set this_archive , once after the second."
I have recently subscribed to Arq Premium. I’ve set it up to only back up from a folder, where I intend to place all items I want to backup.
Am I ok to simply store my DEVONthink databases in that folder or do I need to do something else?
That should be sufficient. But you should also have a Timemachine or other backup strategy in place to safe all your data.
I already ready run a CCC to external disk. This is essentially for my offsite backup. I was just wondering if DT database worked ok in a folder backed up by Arq.
I’m assuming that I can open and work from the DT database from the Arq folder?
