My favourite handwriting tool is the Notability app on an iPad with an Apple pencil
The note is saved in Devonthink, in ocrâd pdf format
Hi Eric,
Havenât done a video as Jim @BLUEFROG has already explained that the contextual menus only work on one item, so this was why I experienced this behaviour; the reason it confused me was that it showed both items as selected with a tick, so Iâd thought the menu function would act on all selected items. Would be great if it were possible for the menu functions to work on all selected items, as this would avoid any difficulty or inaccuracies when attempting to drag and drop. Did you still need a video clip to clarify?
On a separate note, Iâve discovered that Iâve got a Groups in my Favourites that refuse to be removed however many times I select âRemove from Favouritesâ in the long press contextual menu. Is this a bug? Thought I should let you know. Maybe should try removing it on my Mac and see if DDTG3 follows suit?
Weird thing is that if I add a file or a group to Favourites using my iPad on DDTG3 I can remove it again, but not any of the others. Iâve also got one group that appears in my Favourites list with a black Star shown next to it (unlike any of the others) and this item doesnât even have the option listed to âRemove from Favouritesâ in the contextual menu! See screenshots
A sync issue perhaps?
.Favorites with a star are set in the Files app and just mirrored in DEVONthink To Go.
Except when theyâre notâI have starred favorites in DTTG 3.0.2 that are not favorited in the Files app and I canât seem to remove them from Favorites in DTTG. Any other possibilities?
Reboot the device and check Fileâs favorites again. Itâs still a buggy application so perhaps itâs just not showing them.
Thanksâalways sensible advice. However, I restarted the device and the same starred folders are still in my DTTG favorites.
Youâre welcome. But are they in Files.appâs Favorites?
They are not in the Files.appâs favorites.
In this case please paste the following special URL into Safariâs address bar on the device and press the Enter key:
x-devonthinktogo://fix-favorites
This clears favorites âstuckâ from version 2. Does it do the trick?
That worked â Favorites is now cleared of all starred folders â thanks!
Updated to latest version of DTTG (3.0.3) and I was pleased to discover that after selecting multiple items the Organise tool in the menu bar below gives the option to move multiple items to a specified destination (in addition to drag and drop) as well as duplicate and other super handy options. Thank you so, so much for this - itâs a HUGE time saver when youâre spending a lot of time on DTTG rather than the Mac version. Great improvement,
Hadnât realised you could Mark items or folders as Favourites in Apples Files App or how that impacts on how DDTG can interact with them afterwards - hence the star! All sorted now thanks.
I was having a few major syncing issues (not just with DDTG but also on Mac version using WebDav on my Qnap NAS since a recent upgrade) but in the end I followed Jimâs @BLUEFROG advice (on another thread) and set up a new syncstore and finally got everything working just right. Did have a lot of Ghost files at one point but pretty much all sorted now (phew!) - much thanks to @BLUEFROG
Youâre very welcome!
Did you check out the awesome context menus available when you long-press on an item? Theyâre discussed in the ? > Help > Manage Items > Context Menus.
Thanks for that pointerâŚI had missed that. Very useful.
