You’re welcome!
By the way, it should use the last used parent, so if you remember where you last replicated the document, that should be the one.
version edits.txt
is the first created document.- Replicated into
g01
- Replicated into
g02
- The document and two groups were moved to the indexed
M
group. You can see the reported path is theg02
folder.
