I’m a long-time owner of DEVONthink Pro Office. I used it for a couple of years for research projects then fell away from it for a bit. I’ve kept the application updated and have planned to move my research files back into it.
I’m in the process of doing that now but am running into a consistent problem with the import of any PDF documents that are not PDF + text. None of these, no matter the language of origin (French + English) nor the resolution (+150 dpi in all cases), will convert to PDF + text. All of the documents that have failed to convert can be converted by FineReader. In every case, when I select an image-only file for PDF conversion within DPO I get this error message:
Couldn’t set the languages library for the OCR engine.
ERR_BAD_ARGUMENT
This happens for DEVONthink Pro Office 2.9.15, under macOS 10.12.6. A small but significant number of the pdfs I’d like to import are high-res, so this is a show-stopper for me.
I welcome any advice that may be offered.
