“create web document from” and “download web archive from” are both in the DEVONthink Pro 2 Applescript dictionary.
What is the difference? Which command do i use to make webarchives (which seem to be called web documents in some places in DT Pro 2?) from a given url?
“download web archive from” downloads only the web archive data but doesn’t create a record on its own. The data can of course be used to create a record later or to create a file.
However, since version 2, the easiest way is to use “create web document from” which supports also images or PDF documents referenced by the URL
