I’m trying to create a shortcut for an apple script (using forum advice), and finally realized it might be failing because there are two apple script menu items called “Append Selected Text” – one under Comments and one under Rename.
I’m guessing the best route would be to rename one of them, but when I go to the scripts folder, the script doesn’t have that name in either case. For the Comment version, the script title is Add Selected Text to Comment. For the Rename script, the script title is Append Title. I’m not sure where the file is that redirects the menu title to the script.
Or is there some other way to make this work? Thanks!
Missed that it unfortunately doesn’t work with the scripts menu. But it should be possible by adding 3 underscores and the desired shortcut to the filename, e.g.
Add Selected Text to Comment___SHIFT + CTRL + OPT + CMD + A.scpt
Oh, this seems so close! Adding to the filename didn’t work. I tried it with and without the spaces next to the + signs, in the Rename folder: Append Title___SHIFT + CTRL + OPT + CMD + A.scpt and yes, three underscores. Any other thoughts? Thanks.
Why does that work? Is this specific to DEVONthink, or do 3 underscores and a shortcut do magic elsewhere in macOS? I’ve never come across this solution before, and by pure coincidence was wondering how to do it just this morning
