Custom Metadata looses input focus
When entering values into my custom metadata using the “Data” Inspector sidebar, the fields keep loosing the input focus, so data entry is annoying, sometimes extremely annoying. It can lose input focus after just a few letters even when I type at a fairly high and regular rate, and my input is lost.
There does not appear to be much else happening on my computer at the time, and I have not seen this anywhere else in DT.
I have 4 custom metadata (a date, an integer, a one-line text and a multi-line text). The issue affects them all, with the possible exception of the integer.
DT 4.2.2 (have seen it going back to some of the last DT3 versions)
MacOS Tahoe 26.4.1. Mini M1 + Air M2.
Welcome @FankleTheCat
What method are you using in DEVONthink’s Sync settings?
Set the Synchronize interval to something other than Automatic, e.g., Every 5 minutes, Hourly, or Manually and see if the behavior perists.
