hi there,
i have a v1.5 db mostly full of scanned documents which is about 4.5 gb in size.
when i try to open/convert it to dt pro office, i get a resulting db of about 3.3 gb. there is a large number of groups including their containing files missing.
the conversion log doesn’t show any errors but i can see that the export is handling about 3000 files while the import is importing only about 2000 files.
unfortunately, i have copied dt 2.0 over my old version of dt 1.5 and also just suffered from sudden hdd death syndrome twice over the last 6 weeks. in one of these crashes i lost my downloaded dmg of dt 1.5.
so either i find a way to fully import my databases into v2.0 or i need a link to re-download the latest 1.5 (1.5.4?) version, so that i can access my data. any suggestions are most appreciated.
thanks,
olaf
