True, but in this instance, the monochrome image is converted to JPEG. When the JPEG is compressed to make the file size reasonable, then there is definitely loss in quality.
cturner:
So just OCR your documents outside of DTPO. Just because the OCR is there, doesn’t mean you have to use it there.
Yep, just trying to find the best way to automate it. And make it teachable so my wife can do it too. I had a sample workflow using Acrobat 8 above. It doesn’t seem that ABBYY is Applescriptable.
