Sorry- wrong link
This should work with no registration
Sorry- wrong link
Thanks you. I think I need the help from @LucB Any ideas Sir? Thanks in advance
This was the exact reason why I was hesitant to switch to JXA at first - and it still might happen, but so far my experience has mainly pointed out bugs which seem to be fixable if the developer wants to (thanks @cgrunenberg)
@chrillek listed a few of those. My gripe indeed is that Library support in JXA is poorly implemented (e.g. a Library only exports individual functions, not objects). This means having to resort to āhacksā like: Loading other javascript modules? Ā· Issue #1 Ā· JXA-Cookbook/JXA-Cookbook Ā· GitHub (which works and is OK for me).
Iāve often thought what @chrillek was on about when referencing JXA in comparison to AS on this forum. But Iāve completely rewritten 3 of my main scripts from AS and JXA recently and the scripts have become better to read, less error-prone and (much!) more flexible. So although JXA might still pose problems, Iām happy that Iāve switched.
Also, recently Iāve added some iOS specific interactions using Scriptable which is also JS-based and it does help that all my other scripting now is in JS too.
Iād never heard of Obj-C blocks before now, but reading from e.g. Objective-C Blocks it seems theyāre basically the same as lambda function in other languages (like Python, which I understand a bit). @chrillek would ObjC-block be helpful, considering you could also bring ObjC into JXA and use anonymous functions there? Iām sure Iām missing something as I havenāt been needing something like ObjC-blocks, but just wondering.
I think being able to keep things as lightweight as possible in things that I use often like Smart Rules using something like Node seems like a heavy-weight solution.
You are referring to a limited range of experience. I generally would not anticipate specific JXA fixes.
Dear @cgrunenberg and @LucB,
There is one issue with this script. Hook canāt get the link from a folder in DT (for PDF file and video file, it works well). Any idea for this issue?
Iām not seeing any issue with getting the reference URL from a group in DEVONthink. However, I also just rewrote the Get Name and Get Address scriptsā¦
if exists content record then
-- A content record is also a property of the application
-- Content record applies to all think windows
-- If a document window is open, there IS a content record
-- A viewer window requires the view/edit pane to be visible to have a content record
return reference URL of content record
if class of think window 1 is equal to viewer window then
if selection of think window 1 ā {} then
set sel to (selected record 1) -- Get only the first selected record
return reference URL of sel
else
-- The group selected in the Navigate sidebar is the root of the window
return reference URL of root of think window 1
return name of content record
return name of sel
else
return name of root of think window 1
Does that work for you?
Dear @BLUEFROG,
Thanks but it is actually not what I wanted. Your new scripts are somehow similar with the default scripts in Hook which means I can retrieve the group or file markdown link (clickable URL) but without deeper parameters in it.
However, what I wanted, also the topic of this discussion here, is that I can retrieve the page link from the PDF file or the frame link from the video file. In addition, the name can be changed accordingly by adding the page number or frame offset time such as [DT Help page 3](x-devonthink-item://<uuid>page=3), something like this.
For group, since there is no parameter of page or frame, just remain like [DT folder](x-devonthink-item://<uuid>).
You can refer to the scripts that @cgrunenberg wrote below.
As to blocks: there are some objc frameworks where theyāre needed as kind of callback functions. And I was not able to figure out how to do that in JXA. Anonymous functions donāt work.
The rest (Scriptable, nose) is too off-topic here.
Thatās indeed true Jim. So far most JXA issues Iāve encountered come down to bugs, rather than inherent problems with JXA.
Thatās quite different to my experience - so far most āfixesā for JXA were just workarounds as it was actually a shortcoming/bug of JXA. E.g. like this one:
DEVONthink will handle this but shouldnāt have to.
I see - weāre talking about the same thing here, from my perspective it seems like a bug, but as a developer from your perspective I now understand they are JXA bugs. Too bad the JXA implementation seems so brittle ![]()
You mean that DT is actually fixing a JXA shortcoming by use of a workaround?
Exactly.
I did read the manual and support documents but I cannot find a way to link specific Markdown sections or rich text paragraphs. Is there an explanation or link you can point me to so I can create a ādeepā link to a specific section of a document? Thank you!
Thatās e.g. possible via the contextual menu in the text editor or via the Table of Contents inspector too.
Thank you!
Dear Sheng, I found [johnsidi]'s ( @ hook forum) script worked well for me to get URLs for a specific PDF page using hook. Maybe it will work for you.
if exists (content record of window 1) then
-- current open item
if type of (content record of window 1) is PDF document then
set RecordLink to the reference URL of (content record of window 1)
set PDFpage to current page of window 1
set DEVONthinkLink to RecordLink & "?page=" & PDFpage
return DEVONthinkLink
else
return reference URL of (content record of window 1)
if class of window 1 is in {viewer window, search window} then
set selected_items to selection of window 1
if (count of selected_items) = 1 then
if type of item 1 in selected_items is PDF document then
-- current selected item
set RecordLink to the reference URL of item 1 in selected_items
set PDFpage to current page of viewer window 1
else
return reference URL of item 1 in selected_items
-- selected group
return reference URL of root of window 1
Thanks @oriexm
Scripts @cgrunenberg provided above could already get the PDF page through Hook.
The new browser Arc has a ācopy to highlightā feature which works pretty good. Is this maybe a good option for DT, too?
In Arc it generates your post as:
(main address)/t/deep-linking-hook/69403/10#:~:text=You%20can%20actually%20create%20links%20in%20DEVONthink%20to%20e.g.%20PDF%20pages%2C%20Markdown%20sections%2C%20rich%20text%20paragraphs%20or%20to%20a%20video%20frame."
It seems like a search query so it should work only for longer highlights and not for example one word. But its good enough I think.
Item links support already ?search=text queries, a script could be used to generate them for the currently selected text.
Thatās nice. The only problem is that I donāt have any scripting skills. Sadly, Iām one of those who can only rely on other knowledgeable people.
Does somebody know how to do this? That would be really nice.
@LucB ?
