A few questions re the arrangement of tags for index files/groups and macOS folder:
(1) What’s the 3.0 default setting for "DisableFinderTags: DEVONthink no longer exports Finder tags. On | Off "?
(2) From the previous thread, I understand that the default setting is On. Does that mean whatever tags I add/delete/rename on index files in 3.0, nothing will change to the tags of the same index files in macOS Finder?
(3) If I open a 2.n database in 3.0 that contains index groups/files AND I never open the same database in 2.n again, will 3.0 automatically extract/convert all pre-existing tags of those files into each record’s metadata? Which means that I can now batch-delete all tags of those files in macOS Finder, and DT3 will retain all tags that are assigned to each index file? e.g., I will see no tag is attached to a specific file in Finder but can see all the tags I assigned in 3.0 for the same item while in 3.0.
The reason I am asking: the management of tags consistency between DT and index folder is used to be quite problematic when users (i.e. myself) keep moving/duplicating files and folders in macOS Finder and/or if index folders are occasionally un-index and reindex to 2.n (house cleaning of HD, change of folder’s name and location in Finder, etc.). I also have many experiences of needing to cleaning up some sticky/residual tags in 2.n after I rebuild the database. This is not a problem of DT but more of my messy files management in Finder. But if (2) and (3) are the correct understandings, I can now dedicate the tags management task to DT 3.0 as long as I never need to use/search for tags outside DT.
Please advise and thanks in advance.
