I am trying to automate some activity with DevonAgent Pro. Is it possible to the following:
start a search with a search set and topic data supplied at the command line?
OR
start a search with a search set and topic data supplied via apple script/automater?
AND
automate the generation of the report to a specific location on the file system when a search completes, either via DA directly or via an apple script, automator or command line option?
DEVONagent’s AppleScript dictionary contains the verbs to do most (perhaps all) of what you described.
DEVONagent doesn’t have a built-in command line interface, but there are examples in the DEVONagent Scripting portion of this forum from a user who wrote Ruby command-line wrappers for DEVONagent scripts.
So I see how I can start a canned search with a set like this:
tell application "DEVONagent" to search using set "xxx"
This works as long as set xxx is defined.
But, if I want to pass search terms into a common set like:
tell application "DEVONagent" to search using set "web (fast)"
How do I pass the search terms in? I don’t see a variable to use to pass the terms.
Also, in the dictionary, I don’t see any commands for running the report mechanism that is built into Devonagent. Are there commands or something not in the dictionary seen in script editor?
I don’t mean to be dense, but any links to docs or the like would be much appreciated!
I did just find the query part thanks to another post:
This works:
activate
set theQuery to "test"
get URL "x-devonagent://runPlugin?identifier=com.devon-technologies.internet.plugin&query=" & theQuery
Thanks for that.
I’ll try and find some reference to the url structure. I have the slide deck manual, but saw nothing in it about this stuff.
Is there such a mechanism for the report generation as well, or perhaps a URL input? Is this URL mechanism defined in documentation anywhere?
Report generation – take a look (in AppleScript Editor) at the “Send (Mail).scpt” that is located at ~/Library/Application Support/DEVONagent/Scripts/Results/Send (Mail).scpt. This script can be refactored to send a report to a different location than mail. (Be sure to copy before editing!)
All of the scripts in Scripts folder are useful for learning the DEVONagent scripting dictionary. Also, browsing the dictionary in AppleScript Editor.
OK, I have tried to refactor the script using some code from the web. It is still not functioning, and I have no idea why? I put the displays in to try and troubleshoot and it gets to section 3, but it is not writing the file to disk…
-- Send results (Mail)
-- Created by Christian Grunenberg on Jun 04 2008.
-- Copyright (c) 2008. All rights reserved.
-- the email address of the recipient (if no address is defined, the mail is not automatically sent)
property pRecipient : ""
if not (exists search window 1) then error "No search window is open."
set theSearch to search window 1
if searching of theSearch then error "Search is not yet complete."
set theResults to search results of theSearch
if (count of theResults) is 0 then error "No search results."
set theText to ""
set theSubject to name of theSearch & ": " & ((count of theResults) as string) & " results found"
repeat with theResult in theResults
set theTitle to (title of theResult) as string
set theDescription to (summary of theResult) as string
set theURL to (URL of theResult) as string
if theDescription is not "" and theDescription is not equal to theTitle then
set theText to theText & theTitle & return & return & theDescription & return & return & "<" & theURL & ">" & return & return & return
else
set theText to theText & theTitle & return & "<" & theURL & ">" & return & return & return
display alert "got to 1"
set this_file to ((("/Users/xxx/Dropbox/DevonDrop/") as string) & "test.txt")
my write_to_file(theText, this_file, false)
if error_number is not -128 then display alert "DEVONagent" message error_message as warning
display alert "got to 3"
on write_to_file(this_data, target_file, append_data)
set the target_file to the target_file as string
set the open_target_file to open for access file target_file with write permission
if append_data is false then set eof of the open_target_file to 0
write this_data to the open_target_file starting at eof
close access the open_target_file
return true
on error
close access file target_file
return false
end write_to_file
