Hello,
I am using DEVONagent Pro on Apple’s latest OS build at this writing: 10.12.1
Everytime I launch the app from the Dock, I receive a pop-up message asking me to install DEVONagent in the Applications Folder - which is where it is.
The Dock icon was created in the usual way by dragging the installed application from the actual software in the Applications folder.
Is there anyway to stop this?
I’ve attached a screenshot with an arrow detailing the problem.
Thank You! - James
