Thank you so much for this script! I’m so grateful. Unfortunately, I have been unable to get it to work so far. When I click on the script in DEVONthink nothing happens. When I try to run the script in the script editor, this message comes up:
error “The variable fileContents is not defined.” number -2753 from “fileContents”
I don’t know if this is because I don’t know what to put for ‘group’ so I just left it as it was. I’m a bit confused and would really appreciate any help anyone could give me. I’d be so grateful.
Thank you!
Patrick
This is my entire script, in case it helps work out what the problem is:
--Location of this script and its work files:
set workFolder to "/Users/Patrick/Library/Application Support/DEVONthink Pro 2/ZotDevon.scpt"
--The name of the group in DevonThink where you wish to create folders/notes:
set groupName to "/Sources/"
--Name of file containing new entries to add:
set newFile to "new.txt"
--set the formate you want to have for the title
-- 1. Author - Title
-- 2. Title - Authors
set formatOrder to 1
--if you are debugging or have run the findnew.rb script already, set skipscript to one
--to jump directly to the DevonThink import process. Leave as 0 otherwise.
set skipScript to 0
on split(someText, delimiter)
set AppleScript's text item delimiters to delimiter
set someText to someText's text items
set AppleScript's text item delimiters to {""} --> restore delimiters to default value
return someText
end split
on readFile(filePath)
set progressFile to ((POSIX file filePath) as string)
set fileContents to read file progressFile as «class utf8»
if error_number is -39 then
--I think this happens when they are writing and reading at same time…try again
delay 2
return fileContents
end readFile
on existsFile(filePath)
tell application "Finder" to set fileExists to exists my POSIX file filePath
return fileExists
end existsFile
on formatTitle(dataArray, type)
set titleData to item 3 of dataArray
if titleData is "" then
set titleData to "Untitled" & item 2 of dataArray
set authorData to item 4 of dataArray
if type is 1 then
set returnData to titleData
if authorData is not "" then
set returnData to authorData & " - " & titleData
return cleanTitle(returnData)
else
set returnData to titleData & " - " & authorData
end formatTitle
on replace_chars(this_text, search_string, replacement_string)
set AppleScript's text item delimiters to the search_string
set the item_list to every text item of this_text
set AppleScript's text item delimiters to the replacement_string
set this_text to the item_list as string
return this_text
end replace_chars
on cleanTitle(theTitle)
log "Pre: " & theTitle
set returnData to replace_chars(theTitle, "/", "-")
log "After: " & returnData
return returnData
end cleanTitle
on cleanup(workFolder)
--Now that import is complete, delete the "new.txt" file
if existsFile(workFolder & "new.txt") then
set y to do shell script "mv '" & workFolder & "new.txt' '" & workFolder & "lastimport.txt'"
--Delete the backup files too
if existsFile(workFolder & "keys_backup.txt") then
set y to do shell script "rm '" & workFolder & "keys_backup.txt'"
if existsFile(workFolder & "lastupdate_backup.txt") then
set z to do shell script "rm '" & workFolder & "lastupdate_backup.txt'"
end cleanup
-- END METHODS -------------------------------------
if skipScript is not 1 then
--check to see if there is a key and udpate file if there isn't then make an empty one
if existsFile(workFolder & "keys.txt") is false then
set a to do shell script "touch '" & workFolder & "keys.txt'"
if existsFile(workFolder & "info.txt") is false then
set a to do shell script "touch '" & workFolder & "info.txt'"
if existsFile(workFolder & "lastupdate.txt") is false then
set a to do shell script "touch '" & workFolder & "lastupdate.txt'"
--check to see if there are leftover backup files and use them if there are
if existsFile(workFolder & "keys_backup.txt") or existsFile(workFolder & "new.txt") then
set myanswer to display dialog "The last sync did not complete. Do you wish to cancel, look for a backup of pre-import list of entries and ignore any downloaded entries, or first just import already downloaded items and cleanup (You can sync again afterwards)." buttons {"Cancel", "Look for Backup", "Import Downloaded Entries"} default button 3 cancel button 1
if the button returned of myanswer is "Look for Backup" then
set a to do shell script "mv '" & workFolder & "keys_backup.txt' '" & workFolder & "keys.txt'"
if existsFile(workFolder & "lastupdate.txt") then
set b to do shell script "mv '" & workFolder & "lastupdate_backup.txt' '" & workFolder & "lastupdate.txt'"
else if the button returned of myanswer is "Import Downloaded Entries" then
set a to do shell script "rm '" & workFolder & "keys_backup.txt'"
set a to do shell script "rm '" & workFolder & "lastupdate_backup.txt'"
set skipScript to 1
--make a copy of our list of database keys in case something goes wrong during sync
set y to do shell script "cp '" & workFolder & "keys.txt' '" & workFolder & "keys_backup.txt'"
set z to do shell script "cp '" & workFolder & "lastupdate.txt' '" & workFolder & "lastupdate_backup.txt'"
--run ruby script to determine what IDs are missing
set x to do shell script "'" & workFolder & "findnew.rb' > /dev/null 2>&1 & "
set startstat to split(readFile(workFolder & "info.txt"), "/")
set totalitems to item 2 of startstat
set abortmission to false
tell application "ASObjC Runner"
-- set up dialog and show it
reset progress
set properties of progress window to {button title:"Cancel", button visible:true, message:"Checking for new items.", detail:"Looking for Zotero items not yet imported.", indeterminate:true}
activate
show progress
set isdone to false
delay 1
--with timeout of 60 seconds
repeat while isdone is false
set mystats to split(readFile(workFolder & "info.txt"), "/")
log mystats
set currentitem to item 1 of mystats
set totalitems to item 2 of mystats
--reduce chance of annoying error as read/write happens at same time during large library import
if totalitems < 200 then
delay 2
else if totalitems < 500 then
delay 3
else
delay 6
if currentitem = "Done" then
exit repeat
if totalitems > 0 then
set properties of progress window to {detail:"Getting Data: " & currentitem & " of " & totalitems & ".", current value:currentitem, max value:totalitems, indeterminate:false}
if button was pressed of progress window then
set abortmission to true
exit repeat
--end timeout
--set progressMade to readProgress(workFolder)
activate
if abortmission is true then
set properties of progress window to {detail:"Operation cancelled. DevonThink database not modified."}
delay 1
hide progress
error number -128
else
set properties of progress window to {detail:"Found " & totalitems & " new items including attachments and notes."}
if totalitems is "0" then
delay 1
set properties of progress window to {detail:"No items found."}
delay 1
hide progress
set iamdone to cleanup(workFolder) of me
error number -128
--read the file with new entries to be added
set filetoread to workFolder & "new.txt"
set newEntries to readFile(filetoread) of me
--split it into separate lines
set entryList to split(newEntries, "
") of me
if the number of items in entryList < 1 then
--There must be at least one entry to import
display dialog "Could not find any downloaded entries. Nothing to import"
tell application "ASObjC Runner" to hide progress
error number -128
--add all the attachments and notes last, extract them and add them to end
set normalList to {}
set endList to {}
log the number of items in entryList
reset progress
set properties of progress window to {button title:"Cancel", button visible:true, message:"Extracting attachments.", detail:"Putting attachments and notes after all other items before importing into DEVONthink.", indeterminate:true}
activate
show progress
repeat with newEntry in entryList
if newEntry is not "" and the number of words in newEntry > 1 then
log newEntry
if word 1 of newEntry is "attachment" or word 1 of newEntry is "note" then
set endList to endList & {newEntry}
else
set normalList to normalList & {newEntry}
set sortedList to normalList & endList
tell application id "com.devon-technologies.thinkpro2" to activate
--cycle through each new entry and add it to DevonThink
reset progress
set properties of progress window to {button title:"Cancel", button visible:true, message:"Importing downloaded items into DEVONthink.", detail:"Looking for Zotero items not yet imported.", indeterminate:true}
activate
show progress
set mycount to 0
repeat with newEntry in sortedList
set mycount to mycount + 1
set entryData to split(newEntry, " ") of me
log entryData
set finalTitle to formatTitle(entryData, formatOrder) of me
set entryType to item 1 of entryData
set entryKey to item 2 of entryData
set entryParent to item 5 of entryData
set entryAtType to item 6 of entryData
set entryURL to item 7 of entryData
set properties of progress window to {detail:"Adding item: " & mycount & " of " & the number of items in sortedList & ".", indeterminate:false, current value:mycount, max value:the number of items in sortedList}
exit repeat
log finalTitle
set theDatabase to current database
if ((entryType is not "attachment") and (entryType is not "note")) then
if not (exists record at groupName & finalTitle) then
set theGroup to create location groupName & finalTitle in theDatabase
set the comment of theGroup to entryKey
if entryURL is not "" then
set the URL of theGroup to entryURL
set newRecord to create record with {name:finalTitle, type:rtf, rich text:finalTitle, URL:"zotero://select/item/0_" & entryKey} in theGroup
if entryType is "book" then
set entryIcon to "treeitem-book.png"
else if entryType is "thesis" then
set entryIcon to "treeitem-thesis.png"
else if entryType is "journalArticle" then
set entryIcon to "treeitem-journalArticle.png"
else if entryType is "newspaperArticle" then
set entryIcon to "treeitem-newspaperArticle.png"
else if entryType is "manuscript" then
set entryIcon to "treeitem-manuscript.png"
else if entryType is "case" then
set entryIcon to "treeitem-case.png"
else if entryType is "bookSection" then
set entryIcon to "treeitem-bookSection.png"
else if entryType is "document" then
set entryIcon to "treeitem-attachment-file.png"
else if entryType is "webpage" then
set entryIcon to "treeitem-webpage.png"
set iconPath to workFolder & "icons/" & entryIcon
set thumbnail of theGroup to iconPath
else
--We should have passed all normal entries now so we can find them by the Key in the comment
set parentRecordList to lookup records with comment entryParent in theDatabase
--If one record with the parent key is found then let us add children to it
if the number of items in parentRecordList is 1 then
set parentRecord to item 1 of parentRecordList
if not (exists record at path of parentRecord & "/" & finalTitle) then
if entryAtType is not "text/html" then
set myurl to "zotero://select/item/0_" & entryKey
else
set myurl to entryURL
set newRecord to create record with {name:finalTitle, type:rtf, rich text:finalTitle, URL:myurl} in parentRecord
if entryAtType is "text/html" then
set entryIcon to "treeitem-attachment-web-link.png"
else if entryAtType is "application/pdf" then
set entryIcon to "treeitem-attachment-pdf.png"
if entryType is "note" then
set entryIcon to "treeitem-note.png"
set thumbnail of newRecord to iconPath
set properties of progress window to {detail:"Import complete. " & mycount & " entries or attachments added."}
delay 2
hide progress
