In DT3, when selecting a group from the document panel (the center panel), the info panel will correctly shows the info of that group. However, if you select that group from the sidebar, the info panel shows “No Selection”.
Also, you cannot sort the group manually via sidebar, it can only be done in the document window. These made sidebar quite awkward to use. Will it be improvement in the future?
