DEVONthink almost lost after disconnect a second monitor
Situation:
  • MacBook (10.15.7) with a second monitor connected via a hub
  • DEVONthink (3.6.1) is on second monitor
After safely disconnecting the hub (and also the second monitor) the MacBook normally does move all the apps from the second monitor to the active screen on the MacBook. Not with DEVONthink.
DEVONthink does not really moving on the active screen - you can only see a little edge.
Maybe you can check and correct this.
Thanks
Henk
Could you please post a screenshot of DEVONthink before/after disconnecting or send them to cgrunenberg - at - devon-technologies.com? Thanks in advance!
