Thanks for sharing! I have to say, I really like the idea of a monthly journal document. It sounds like a useful dumping ground for those sort-of-related-but-not-really-related thoughts and connections that pop up when writing. At the moment, for me, these either 1) get scribbled down on a Post-It and added to a pile of other Post-Its (which survives until it becomes overwhelming, at which point I scoop them into the bin!); or 2) take me down a rabbit hole so deep that whole days are lost reading about something that which may (or may not) be useful at some point in the future. Having a single document for these unfiltered thoughts, free of any particular structure seems so obvious. Of course, this only works if the document is reviewed regularly — which is why I like the idea of your monthly document. Do you schedule in a review at the end of each month to incorporate thoughts into a more permanent form/filing system?
This appears to have a correlate to GTD where you clear your head by writing down all that’s on your mind and review those items at a certain frequency. That leaves for more ‘space’ in your brain to analyze, as you’re not constantly keeping track of those ideas.
You might consider using a mind map structure to do that, and create one with groups in DT, Come to think of it, @BLUEFROG and @eboehnisch: would it be an idea to have the possibility to create a topology view of the groups in a DT database? You can use the classic tree view in the sidebar of course, but space might be limited to unfold them all and look at them at a glance. Like the related words, word cloud or frequency graph do with the data within a document, it would be a way to visualize the groups and their containing files.
In line with GTD I try and include a verb and ‘taskify’ those ideas, although of course the more abstract the idea gets, the more difficult this becomes. The concept is though, that those ideas become more actionable when reviewing them. You could include verbs like ‘assess’, ‘write’ or ‘search’ for example. In my experience jotting down some fuzzy concept is quick, but you might not understand after a month what you tried to tell your future self.
As to the method of the review you asked @spoiltvictorianchild about, I personally depend the frequency of it on the priority of the idea/task. You could for example tag an idea as ‘daily’, ‘weekly’, ‘monthly’, ‘quarterly’ or ‘yearly’ and have a smart group that displays those ideas in a corresponding group. So if an idea has high priority, you tag it ‘daily’. You then review the ‘daily’ smart group on a daily basis (and perhaps set a daily alarm for it), and you’ll run into that idea every day. Likewise, the ideas with a lower priority get a timeframe tag that is larger than ‘daily’ and you’ll not be bothered to assess those before the appropriate time. But of course you’re free to look over them at every moment you want to.
So more like a mind map with the root in the middle?
Yes, exactly.
Whether it’s feasible or necessary to display all containing individual files at the lowest level is something to research, but if your group structure grows over time it can be difficult to keep track of the structure just by looking at the tree view.
Definitely an interesting idea but hard to solve from a UI standpoint. We’ll keep it in mind.
Perhaps the ‘related words graph’ could be adapted to use groups and allow the spanning tree protocol to only use up/down relation of those groups. Clicking a bubble expands the groups attached like in the tree view.
You’d get a group view that might look something like this:
PPL CPL
Certification - Planned - ATPL - (many more groups)
Flying DB (root) — Navigation — Airport Charts
Flight plans - Archived - before 2020
Planned 2020
Oh, I’m glad to hear you found this useful! As I wrote above, I print it out at the end of each month and go through it, so that’s a built-in review. These days I’ve turned it into something of a “work journal,” where I am logging the hours I work, what I did, and so on. At least for this month, I’m actually not breaking off and creating a new monthly file, because I think that break is arbitrary and this way I can easily scan my work history in one place. I’m still transcribing voice notes and putting random things there, but these days I’m mostly writing things for my dissertation so my freewriting is happening in one of a couple of Scrivener documents related to that.
This is a good reminder to pull out ideas that don’t fit in that project and keep them somewhere, though. I didn’t really write this above but I’m trying to embrace redundancy as a principle, to just give me more chances to see something. As a result, some of the things that make it in to the journal are notes I’ve already written somewhere else – I’ve started to keep a collection of small standalone notes and quotes in DT, almost like a little blog for myself. There’s a lot of overlap between this stuff, and as I said I print out the journal once a month, lol. Like I said, embracing redundancy!
@anon6914418’s idea of tagging ideas with the frequency you should revisit them sounds helpful. I don’t think I can keep up with that level of organization, but I have a couple of tags like “possible epigraphs” or “would teach this.” I forget if I have one for “could be an article” or just “rabbit hole to chase down in the future” – I’ll definitely think of expanding my tagging system in that direction.
I’ve found your comments (and the entire discussion) really helpful as I realized my own research diary within DTP needs tweaking. Separating the diary into monthly files and taking out anything that can work better as a separate file sounds super useful.
I would be curious to hear how your workflow might have changed over the past year, as well as any other thoughts folks might have on keeping a research diary in DTP.
Hi, oh yes I’m happy to share how things have developed, as I am still in the process of writing my dissertation (but it’s gonna be done next year, for sure hehe). I’m going to re-read my initial posts to remind myself of how I did things, and then update you below.
So, at some point I switched everything from Word to Markdown. Before, I thought it was important to use Word because I could integrate my Zotero citations right there. At that time, I hadn’t yet figured out how to integrate Zotero with Scrivener, but I have done that now, so I can easily store citation information in plain-text documents. These days, though, when I take my markdown notes on a book/article, I don’t often bother with adding the specific citation key, I’ll just note the page number and move on. But I have enjoyed using Markdown for many reasons, most importantly the ability to use links, and also the ease of using DTTG.
Even after switching over my reading notes to Markdown, I was still doing my monthly journals in Word, but at the start of the year I decided to switch to a daily journal in markdown. I just duplicate a template file every day and add things to it throughout. If I’m being good I’ll also link up basically every markdown file that I create or modify (checking the “Today” folder helps). Again, my whole “system” such as it is is just about leaving myself as many breadcrumbs in as many places so that I might, by chance, stumble across something that then fell out of my head. At the end of the month, I collate the journal files into a Word doc (for format / page number reasons I guess), print that out, annotate and then file it away.
I have been better about pulling out random thoughts / quotes and putting them in a free-form “Journal” folder as individuated Markdown files. (My daily entries sit in a subfolder, hah) I still think most of this stuff will maybe only come in handy down the road when I need to remind myself of some lost thought that I had. It’s all an imperfect science but I do think my system has gotten better!
If you find something that works for you please do share it! It is always really interesting to hear how everyone approaches this challenge. Take care and good luck!
Great only found this today in response to a query. Do you have any tips up to date on scanning some papers from books which are now falling to bits on my shelves. Some over 50 years old but still very useful to me.
Hello! Actually some things have changed in my setup since then (basic setup the same, but some new apps have claimed a big space – hello Obsidian!).
To answer your question: I scan a lot of books using my iPhone (SE), and Readdle’s Scanner Pro: it has very good output, including OCR (though I use DT for that); and things like deskewing the page. It’s worth whatever its costs today. There are good output options as well (export as jpg or PDF depending on your needs). I tend to push these exports to Dropbox or straight to DEVONthink To Go. In archives and working with manuscripts or rare books, it’s a good solution above and beyond the simple phone camera.
Everything depends on the state of your books though (how well they open, how fragile they are). There are higher-end book scanning solutions such as cradles with camera mounts (which you may need if you have larger collections) but for occasional use, Scanner Pro is the thing.
Thank you, exactly within my parameters. My needs are pretty narrow, a few pages really from some falling apart 1960s to 80s paperbacks that are now a bit frail; to reflect on, sometimes formulae and arguments that are hard to get straight.
It means that even if the pages are loose I can get good use out of them. It is, in other words, nowadays very sloooooow reading that I do. I have found though that once starts with these things it tends to grow.
I have to say, though I don’t even really know how it works, I never have any problem finding anything on DEVONthink 3 once it is in there from all sources. I shall have to study the OCR thing so I understand it better.
