Hi… Thanks for the heads up, but I already have a nas. I scan the files to that location and I also generated a folder for the webdav sync.
My question is now how to set up rules to import the fresh added documents from that path to devonthink.
Well, one way to handle this:
- Setup a folder on your NAS where you scans will temporarily be stored
- Setup your Brother scanner to connect to your network share with write access to that folder
- Mount that share in macOS finder (you can automate the mounting on login by dragging the disk icon onto the Login options window of the user account under Settings)
- Install the folder action scripts add-on in DEVONthink
- In macOS right click the mounted network folder and add the “Import, OCR and Delete” script (the file will be copied, OCRed and the original will be put in the trash)
Don’t proceed with any of the steps unless you succeed with the previous step, as it’s more or less useless if one of these doesn’t work.
But this is just one way to do it.
You could also skip the folder actions and use a more modern approach with smart rules and indexing the mounted network folder (although as mention that might be subject to slow network connections). @BLUEFROG has created a smart rule set to replace the above folder action scripts (import, OCR and delete).
The WebDAV sync store on the NAS you’ve already setup is the place where DEVONthink on it’s turn will ultimately store the files. AFAIK there is no way you can scan into the sync store directly, as this needs to be handled by DEVONthink.
One amendment…
I personally do not advise adding a networked volume to your Login Items. If the network is down or the device is unresponsive, it will slow and stall machine startup.
An alias in your Dock or on the Desktop is a good option and allows the Mac to fully and gracefully boot before attempting to load network drives.
Thanks for the hints. Instead of indexing the network share is it also possible for devonthink to import from that location using a smart rule? So that I just can scan to the network drive (which is already set up and works flawless) and that devonthink just imports from there. Maybe detecting only changes, so only fresh files? That way I would have the network folder as an additional backup drive with the raw data?
Or do I need to use something like hazel to move the files from the network drive to a local folder (import folder)?
I couldn’t get it to work properly on a network share when I tried this recently.
I first thought indexing a network folder was not supported as I read in the DT manual that only local and attached drives are supposed to be indexed. As I later understood network folders can be indexed, but that might be troublesome if there is network latency. As I tested with a WiFi connection to approach the share that probably explained my experience.
I haven’t yet tried it with a cabled connection, but certainly will as a smart rule solution reduces the dependency on other software (folder action scripts or other).
Hm…I really clso to drop the project. It´s much more complicated than I thought it would be. Maybe I will give first Hazel a try, for sorting and naming the files. When I have my scanned files in a good folder structure on the NAS, I can then see how to index them with a software. I just don´t want to put too much work in an error prone tool. From my reading in the past weeks there are some many “you have to be careful” and “it might work that way” that I´m not sure whether I want to put my data in that tool.
Maybe I´m just to stupid, I don´t want to blame the software …I´m sure…if you are a pro with it it´s totally fine. But for me as a beginner the threshold is just too high. And I guess the only adavantage it would have for me in contrast to a pure folder structure is the searchablility of the files. Or am I missing something?
Argh just a little bit frustrated right now.
OK, well I really didn’t want to confuse you and tried to latch on to your knowledge. But there’s always a possibility with these communities the gap is bigger than I anticipated.
If you go through the 5 steps I posted 5 days ago. Those don’t use smart rules and should work in both Mojave and Catalina. One by one, at what step do you run into a problem?
I leave it to you whether there is value to a software product of course, but to me DEVONthink is much more than “Finder on steroid”.
Thanks again for all your tipps and the time you invested in answering my questions.
I think I face a multiple layer problem here.
First the scanning:
I can scan using a PC, because direct scanning via network misses some features, like OCR and other. I scan to a network folder. So already here I need to choose what kind of stuff do I scan. I put it directly into the correct folder here which is named like “invoices” “insurrance” and stuff like that.
Now my first problem is to get the stuff in a sorted way into devon think, maybe I would use hazel to rename the files first so that they are tagged by that way for devonthink and move the stuff to an indexed collection folder. Here I could use the smart rule to do OCR if needed and to import the files into the correct group/folder in devonthink. But it seems that I would need to do an extra rule for each file type/name I generated.
Maybe my approach is to complicated.
OK, well it’s up to you of course, but the beauty of a network scanner is that you can place it anywhere with a network connection (be it cable or WiFi). OCR is handled by DT3. What other features do you get from Windows, that you don’t get from scanning to the NAS over your network?
But for now let’s work with your established Windows workflow.
I would suggest to first establish a simple “proof-of-principle” and work from there, instead of thinking through everything in every detail. You can do so once this works. So for now simply scan to one folder on your NAS called “Inbox”.
Then install the folder action scripts from DT3 as mentioned in step 4. Then open macOS Finder, browse to the mounted network folder and right click the “Inbox” folder.
From the context menu select Services (at the bottom) → arrow → and then Folder Action configuration. You get a pop-up to confirm. In the next window select the + button on the bottom left and search for your “Inbox” folder again. Then select the + at the bottom right. Now select the script “DEVONthink - Import, OCR & Delete”. Confirm and then don’t forget to enable the Folder Actions at the top of the window.
Now scan a simple one page document to the “Inbox” and watch as macOS starts the script (you’ll see a cogwheel turning in the macOS menu bar). When done the script has imported the scan into DEVONthink, performed OCR and deleted the original scan into the trash.
The scanning problem is, that I can either use the scanners interface to directly scan to a network. that works quite well and by seeting up multiple “favorites” I can decide in which subfolder the files will be stored on the network. Unfortunately it´s not possible to use the enhancement tools, like correct orientation and remove background and stuff like that with the network settings. Therefore the quality of the scanned files is much worse compared to the quality I get when scanning via PC. But here I need to do the naming manual.
I tried what you described already some time ago and it didn´t work well. But since I´m not a macos guy I don´t want to mess too much on my wives work-laptop.
Do you think it´s aproblem to apply the OCR to an already OCRed document?
