When I use the Safari extension to add websites to DEVONthink the DT window opens most of the time. This started happening in the past week or two.
It’s annoying to have to close the window when all I want to do is add the data to DT. Is there way to prevent this from happening? I haven’t been able to locate a preference setting to change this…
To avoid this, I minimize (cmd+m) Devonthinks window to the Dock. If you hide (cmd+h) Devonthink, it’s window will pop out of the Dock as you describe.
While I use DevonAgent most of the time the above mentioned is also valid for Safari. I never close the window, but maybe minimizing it will be ok for you.
