I am new to DevonThink Pro Office (version 2.8.2). Running OS X 10.10.1.
I have two macs connected through ethernet. I have successively set up a direct synchronisation (following the tutorial video: ‘Synchronizing databases between multiple Macs’).
However, when I disconnect one computer and then re-connect it, I can no longer synchronise. I get the following error message:
Even if I delete the existing connection and try to set up the connection as new I cannot do so as in the ‘Add Direct Connection’ box the ‘Server’ space is empty:
The computers (outside of Devon Think Pro Office) still communicate with each other (i.e. with Finder/Go/Connect to Server I connect from computer 1 to computer 2, or vice versa).
The only solution I have found is turn off both computers, reboot and then set up the connection again.
Is there any way that I can avoid having to do this, as I need to disconnect one of the computers several times a day (i.e. it is a laptop)?
